Headlights come on, but then shut off while driving
Old Jan 14, 2012 | 09:39 PM
Josh Conley's Avatar
Car: 1990 Camaro RS
Engine: 5.0L 305 V8
Transmission: Automatic
Hey everyone, I have a 1990 Camaro RS 5.0 L V8 Auto. Trans. And lately I have been having a problem where my headlights (HB & LB) will come on, but shut off after a short while. This obviously can become a bit scary at night. After they shut off, however, they will usually come back on after a few seconds but not always. Someone told me I probably need a new headlight switch. Others mumbled on about fuses and a relay, but I honestly don't know. Also, I recently had a new ignition switch and Dimmer Switch put in. Any ideas? Any help would be greatly appreciated. Thanks!
Old Jan 15, 2012 | 07:25 AM
Mrs.Crasher0083's Avatar
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
Re: Headlights come on, but then shut off while driving
Yeah that sounds like the headlight switch. I had the same problem not to long ago. The headlight switch has a circuit breaker built into it. When the breaker goes out....itll reset after a short time. You should really check for any loose or scratched wires on the headlights also. Make sure all the grounds are good. If thats all good a new switch will probably do the trick. I think I got mine from AZ for about 12 bucks. Just be careful removing the old switch. theres a screw in part thats plastic and it can break easily......trust me lmao. Thank god for super glue lol. Good luck
Old Jan 15, 2012 | 09:45 AM
Car: 1990 Camaro RS
Engine: 5.0L 305 V8
Thanks for the reply! Im about to head to autozone now while it's still light out haha
Old Jan 15, 2012 | 10:22 AM
Ajaxzem's Avatar
Car: 85 Trans AM
Engine: 305 LG4
Axle/Gears: 3.08
I had the same thing start to happen to me while driving at night. Scared me bad when it first happened going into a corner and they failed. I found i could make it happen with the lights on if i tapped on the switch or wiggled it just right. Replaced it and been working fine ever since then.
1992CamaroGirl
Dec 25, 2017 08:45 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
