Dimmer switch
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
Dimmer switch
I will have to put in another dimmer switch, third one in 3 years.
This one just quit on me while driving at night, I didn't use the switch, the headlights just went out. I switched to high beam and they came back on but now I can't trust it after dark.
Where can I get a switch that I can trust?
Car: 1992 1le z03 1992 b4c camaros
Engine: 305 tpi 350 auto
Re: Dimmer switch
are you sure the dimmer switch is the problem?Is it possible your low beam wire has an intermittent grounding problem somewhere in the harness and causing a short?I would use an ac delco oem switch
3rd, 85, 90, 91, camaro, dimmer, gen, generation, installation, iroc, location, replacement, switch, swith
