heating ac blower control switch
I need to change the blower control switch in the dash right above the radio. I got the front panel off the radio/control area and got the heating/ac part to pull out just a little bit but it seems the wiring behind it won't let it come out anymore.
**I don't know what I'm doing here, only trying to figure it out since I want to drive my car before my hubby will be home next to fix it. This is likely a silly problem, but I'm stuck. Help is appreciated. The guy at the parts store said it was something that I could do on my own.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: heating ac blower control switch
Three connections on the backside viewed from the top of the unit. The problem is probably in the second pic. The slider cable has a tab that pushes into a slot. IIRC, I used a short, flat-bladded screwdriver to disconnect it.
JamesC
Couple more from the bottom of the unit. The little 'circle' in the first pic fits into the cable tab. The two 1/4" screws and the retaining washers can be seen in the second pic.
Here's a link to a promising fix for the switch:
https://www.thirdgen.org/forums/inte...anent-fix.html
JamesC
JamesC
Car: 1987 Trans Am
Transmission: 700 R4
The white thing is selector your switch. The 2 black washers are what you want to remove. That is what I had to use needle nose pliers and a screwdriver on. Also, you can see two 7m screws that have to come off. I thought mine had 1. Just remove both of those screws after you get the "one way" washers off. You are halfway home.
Car: 91 Firbird Formula
Engine: 5.0 TBI
Wow, Thanks. 50 cents at the hardware store and my problem is gone! My HVAC control switch works perfectly now.
The_Phoenix
Feb 4, 2016 07:10 AM
Street Lethal
Aug 13, 2015 08:28 PM
