Need an 88 headlight control module
Old May 20, 2012 | 05:09 PM
misswhitney8's Avatar
Car: 1988 Pontiac Firebird
Engine: V6
Transmission: Automatic
Anyone have a headlight control module for an 88 firebird for sale? I've seen people offer them here for $20, but I can only find them for upwards of $75 (as high as +$300). Is that what I am going to have to pay? Are they available at corporate part stores, or will I have to order one?
Please let me know and thank you all so much! This site is a life saver, or should I say firebird saver!
Old May 20, 2012 | 05:17 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Need an 88 headlight control module
I'm going to check out a CLEAN 88 gta BEING PARTED OUT IN A COUPLE OF DAYS. iF YOU COULD TELL ME WHERE THE PART IS LOCATED i WILL SEE IF THERE IS A GOOD ONE THERE. pm OR EMAIL ME AND i'LL GET YOU MY EMAIL ADDRESS FOR PICS OR OTHER INFO IF INTERESTED. Oops, sorry I just noticed I hit the caps lock, but don't feel like redoing the whole thing.. LMK, Henry
Old May 20, 2012 | 05:41 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Never mind, I found out where it is, I'll LYK what turns up...
Old May 20, 2012 | 06:19 PM
Engine: V6
Awesome! I only have a vague idea of where it is, so I'm glad you know. Waiting for a Chilton manual to arrive. Keep me posted and thanks so much!
Old May 20, 2012 | 09:24 PM
Engine: V6
I now know where the module is. Please let me know if you can find one for me.
Old May 20, 2012 | 09:27 PM
Engine: V6
Also, if the console in the 88 is in good shape or if the hatch motor works, I might be interested in those too.
Old May 20, 2012 | 10:18 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
If he can't get you the module, I have the one out of my 87 I can't use. Some may say they won't work (not sure the year break), but the wiring is the same between the 87 and 92 modules, so it should just plug right in...
Don't have a decent console and I'm keeping the one hatch motor I have, though.
Old May 22, 2012 | 05:23 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Sorry, I may have seen one the other day when I had no idea what it was, but today there were none left.
Old May 22, 2012 | 07:37 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
She needs one from a 87-89 model year firebird.
Lon
Old May 22, 2012 | 09:28 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Well, then, OP, LMK if you want the one I have... I need to clean it up a bit if you do before I can pack it up.
Old May 22, 2012 | 10:42 PM
Engine: V6
Lon is right. I have confirmed that it is the same module for 87, 88, and 89. So, yes I want it! How much are you asking? Have you confirmed that it is in working order?
Thank you so much, everyone, for you help!
Old May 22, 2012 | 11:03 PM
Engine: V6
That's ok. Thanks so much for looking! If you come across any headlight bezels (the black plastic encasements for an 85-90) and don't need them, please let me know. Thanks!
Old May 22, 2012 | 11:14 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I'm pretty sure I still have my old set from when I converted the headlights to the 91-92 parts. I need to look for them before I can get back to you on this.
As for the module, it worked when I took the car off the road and apart back in 2010 (can't believe I've been without for 2 years now ). I have no way to test it now with no harnesses in the car, no battery, and no headlight switch. LMK if you still want it.
Old May 23, 2012 | 01:41 AM
Engine: V6
I want it, if I can get it for a good price. Let me know. Thx!
Old May 23, 2012 | 11:47 AM
Engine: 2.7L V6
Axle/Gears: 4.41
I'll get the module cleaned up shortly and look for the headlight bezels at the same time. PM me an address/zip code so I can get shipping info.
Old May 23, 2012 | 01:48 PM
Engine: V6
Ok, maverick, I sent you a message. Thank you!
Old May 30, 2012 | 01:35 PM
Engine: V6
UPDATE: My headlights now work perfectly, but it wasn't the module.
A fiero guy (gasp!, I know) told me, "The module consists of two separate circuits, one for each motor. Both circuits seldom go bad, especially at the same time. If they both come up even 1 in 100 tries, it is really unlikely the module. Most of the time, when both motors won't run, the light switch is the problem, and it needs to be checked first."
I attempted to switch the module first with a loaner that I knew was working. The lights came up, went down, and then only one came up. So, I gave in and replaced the switch. Low and behold he was correct! The headlights now work perfectly!
Sounds crazy, but actually the module was easier to change out. You have to take off half of the dash to get to switch!
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
TrevinE
Sep 14, 2015 03:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
