Battery cable trouble
Old May 27, 2012 | 11:28 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
The ends on my battery cables are pretty gnarly so I wanted to cut them back and splice them, but can I safely (and legally) do that? Or is there a way to just replace the whole battery cable without a harness swap?
Old May 27, 2012 | 07:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Battery cable trouble
http://www.ebay.com/itm/ACDELCO-PROF...886601&vxp=mtr
http://www.ebay.com/itm/DEKA-00300-B...2dcfd8&vxp=mtr
Old May 27, 2012 | 07:44 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
its a top post.
Old May 28, 2012 | 03:08 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
its a top post.
So do a search for the same in top post config.
Could prob walk into your local parts shop and get generic cables straight off the shelf
Only have to be long enough Batt - starter/ block ,nothing special about them
Old May 28, 2012 | 09:27 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
The negative cable is easier to do; it's right on top. The positive is a bit trickier only because of tight quarters (I have an 8 cyl. TPI) but if you have a jack & stands, it will be easier. Figure about a half hour for removal and re-install of both. I bought Duralast Gold 2 gauge at Autozone for about 13 bucks each. If that's too much, they have less expensive options.
Old May 28, 2012 | 09:51 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Thanks for the advice guys
MM2Robinson
Oct 1, 2017 09:16 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
