Positive Battery Cable
Old Jun 1, 2012 | 08:06 PM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
So the black barrel that encapulates the 8ga wire to the alternator, the 12 ga wires to the fuel pump fuse and the fans, (I believe), to the 0 battery cable is not a fuseable link ? Someone please clarify this for me...
My voltmeter gauge in dash will never show above 11v while driving even at high rpms. New Battery, new alternator. Can my gauge be that far out of tolerance ? I measure 12 volts using a voltmeter from the alternator to battery. Shouldn't I be seeing 13 at the gauge in the dash while driving ?
Old Jun 1, 2012 | 08:39 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Positive Battery Cable
Originally Posted by djmarch
So the black barrel that encapulates the 8ga wire to the alternator, the 12 ga wires to the fuel pump fuse and the fans, (I believe), to the 0 battery cable is not a fuseable link ? Someone please clarify this for me... ?
Only covers the connection.
Old Jun 2, 2012 | 10:25 AM
Seafarer12's Avatar
Car: 92 GMC K2500 LD
Engine: 350 TBI with some mods
Transmission: NV4500
Use a multimeter to check your voltage at idle and 2000 rpm. Check all the connection at the back of your alternator.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
