Window motor regulator spring popped off!!!
Old Sep 3, 2012 | 09:03 PM
Guest
Guest
Posts: n/a
Guys, save my ***!!! In the hell of replacing my passenger window motor, the regulator spring popped off and nearly took my finger with it. How can I put that thing back on?!
Old Sep 8, 2012 | 02:19 AM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Window motor regulator spring popped off!!!
this happened on my driver side, but my windows still go up and down
Old Sep 8, 2012 | 02:21 AM
onewheelpeel's Avatar
Same thing happened to me. But the window still works good without it?
Old Sep 8, 2012 | 08:57 AM
Jeffs82TA's Avatar
slide the spring a little bit down into the regulators slot. the clamp onto the end of spring with vice grip but not really tight. Then rotate spring over the stud and tap it in place with a hammer, takes about 30 seconds to do it.
Old Sep 8, 2012 | 09:15 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Good information and pictures Jeff.
Old Sep 8, 2012 | 11:07 AM
Car: 1984 T/A
Engine: LQ4
thanks
Old Sep 8, 2012 | 02:40 PM
Edwardgp's Avatar
Engine: 454-350
Thank you for taking the time to post this, I am sure it will help a lot of people.
Old Sep 25, 2012 | 06:44 AM
BOTTLEDZ28's Avatar
Transmission: A4
That would be hilarious if it popped off and smashed you in the face. The audience would laugh for sure!!!!!!!!!!!!!!!
Old Jan 26, 2021 | 09:54 PM
kalgran's Avatar
Car: 1992 Pontiac Firebird
Engine: 305 5.0L v8
I understand this is an old dead thread but is there a way to re-tension the spring while the regulator is still inside the door?
got it. Had to take the regulator out. Easiest way by far.
Old Aug 13, 2023 | 10:20 PM
Proland79's Avatar
I made the mistake of not securing the spring before removing the motor from the regulator gear on the left rear passenger door window of a 1998 Chevrolet Suburban. That coil snaps hard, but I wasn't in the way. I would have never seen it coming. Later I read about the danger of laceration of fingers. The replacement process was the same as described here, except the mounting frame required the center to be held on the post, but just barely while the coil was cranked around the retainer post. About a third of the way around the mounting frame was thinner and it was possible to get the center of the coil further into the slot. Narrow vice grips were used, clamped to half the width of the coil, to hold the center of the coil in the post slot, and the entire regulator rig was clamped down to the counter. Ordinary pliers and the grip of death were used to extend the coil to the retainer post while keeping constant pressure on the vice grips.
Old Jul 27, 2025 | 05:13 PM
tarabeara's Avatar
you saved me from losing any of my fingers, thank you so much
charlielamb
Mar 3, 2011 01:44 PM
ĦMR.AWESOME!
Feb 10, 2010 10:59 PM
thirdgenfcarnut
Nov 19, 2008 02:04 PM
92F-bird_5spd
Aug 24, 2005 12:46 AM
