Left side headlights stopped working
Old Sep 5, 2012 | 09:42 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
A few days ago I noticed my drivers side head light was out. I put in a new one, turned the lights on and still nothing. The blinker works though. Hi beams don't work on the left either now. Everything on the passenger side works like it should and all taillights are still working too. The only other electrical problem in my car with lights is with the gauge lights. With headlights on and the gauge lights turned off or down all gauges work fine. But when I turn the gauge lights up the tach and voltage gauge needles don't move they just stick to the lowest point. Any help is appreciated
Old Sep 5, 2012 | 09:59 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Re: Left side headlights stopped working
sounds like a poor ground connection
Old Sep 5, 2012 | 11:11 PM
Gsoleski's Avatar
Car: 1984 Z28
I cleaned off the ground connections for both left and right side. No luck with that so I grabbed a test light and with the lights turned on I don't have power at any of the 3 prongs
Old Sep 5, 2012 | 11:14 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
check fuses, if there good then most likely bad headlight connector
Old Sep 5, 2012 | 11:31 PM
Gsoleski's Avatar
Car: 1984 Z28
all fuses are good. Does anyone know anything else I can try before looking for a new connector?
Old Sep 7, 2012 | 01:22 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
before you replace the headlight connector I would check for power in the wires before they get to the connector. If no power in the wires before the connector then the problem is obviously not the connector.
I do not know much about the headlight circuit itself but would guess there would be a relay somewhere and that could be bad. I would start by looking at wiring diagrams.
Old Sep 10, 2012 | 07:01 PM
Gsoleski's Avatar
Car: 1984 Z28
There isn't any power in the wires, but once they go into the firewall I can't see where they go to. I don't think there are any relays for the headlights
Old Sep 10, 2012 | 07:08 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
All the things you mentioned go through the headlight switch. Have no idea if that's what's causing it or how to check it, but worth thinking about
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 22, 2015 08:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
