head ight dimmer switch
Old Sep 9, 2012 | 10:01 PM
toppgunn77511's Avatar
I have a 1990 iroc, hi beams are n and I cant get it t switch to low beam. Anyone have instructions on how to change the dimmer switch
Old Sep 9, 2012 | 10:06 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: head ight dimmer switch
Remove the lower dash panel below the column, loosen the column mounting bolts and lower it a bit, remove the two 8mm bolts holding it to the column, unplug it, reverse.
OTOH, it is very likely it doesnt need replacing, if it is not adjusted properly it will not work, does the stalk click when you try to pull it for the high beams ? If it doesnt, it needs to be adjusted, the bolt cutouts on the switch are slotted so that it can be adjusted.
Old Sep 9, 2012 | 10:20 PM
The turn signal lever does not click when trying to dim high beams
Old Sep 9, 2012 | 10:23 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Yeah it probably needs adjusting, i've done it before without dropping the column, I forget whether it was by 1/4" ratchet, or wrench, or both, but it can be done, drop the lower panel, look up under there with a flashlight and feel around you'll find it.
Old Sep 9, 2012 | 10:24 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
The rod that actuates the lever, which is the source of the clicking, commonly needs adjusting.
How is the rest of your steering column? Does it "flop" left/right or up/down? Does the tilt mechanism still work? I ask because when that stuff starts to fail, the Hi/Low is commonly affected.
Old Sep 9, 2012 | 10:30 PM
steering column is solid no flopping, i dont know what the tile mechanism is
Old Sep 9, 2012 | 10:34 PM
Car: GTA
Tilt steering wheel. Tilts up away from you/Tilts down towards you.
Old Sep 9, 2012 | 10:41 PM
oh ok yes tilt works fine
Old Sep 9, 2012 | 10:55 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
The rod doesnt adjust, and the rod is not the source of the click.
The switch needs adjusting or replacement.
Old Sep 9, 2012 | 11:16 PM
sounds good ill give it a look, thanks
Old Sep 9, 2012 | 11:24 PM
Car: GTA
http://www.austinthirdgen.org/index.php?pid=16
And duh the the rod doesn't click. But what the rod is attached to the end IS the source of the click.
Old Sep 10, 2012 | 12:46 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
The lever is not the source, the rod is not the source.
As I already posted before your suggesting the rod, or the lever needs adjusting, is the SWITCH needs adjusting or replacement.
Old Sep 10, 2012 | 01:31 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
As you get the idea while you see everyone arguing about the dumb stuff.. Check the adjustment of your switch.. You will see the rod that goes to it. Move the switch upwards toward the steering column. If you still don't get it to work, Replace that switch..
Ghettobird52
Jul 5, 2024 11:18 PM
Dkelz313
Apr 7, 2016 10:38 PM
The_Phoenix
Feb 4, 2016 07:10 AM
86IROC112
Aug 17, 2015 02:00 PM
ZsTransAm
Aug 11, 2015 07:30 PM
