Why won't my battery charge
Old Oct 5, 2012 | 06:27 PM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
New battery, new alternator...Get 12v on the battery + terminal on the alternator, but my voltage is only reading 11 volts in the dash. Should be 14 volts. Could it be the gauge ? Checked all grounds, headlights, relays, engine ground strap, hatchback pull down. Ground off battery to block is good and tight.
Stumped here...Any recommendations on what to check will be appreciated.
Thanks in advance.
Old Oct 5, 2012 | 08:44 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Why won't my battery charge
only 12v at battery with engine running?-that is way low,should be around 14v with engine running.
Old Oct 5, 2012 | 09:53 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
do the cars with gauges also have an "alt" or "volt" light?
if so, is it on with the key on and engine off?
if the light doesn't come on, then check the bulb. that bulb is inline on the circuit that activates the alternator and if the bulb is burnt out, it won't charge.
if it doesn't have that light, are you getting power to the brown wire on the alternator plug with the key on? if not, that's your problem. could be an ignition switch problem.
Old Oct 7, 2012 | 06:04 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
What he said.
camarohelp
Sep 22, 2015 03:19 PM
Johnoooooo
Sep 22, 2015 08:55 AM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
Formula_88AE
Sep 3, 2015 01:47 PM
