vats problem
Old Oct 28, 2012 | 05:30 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
vats problem
ok i own a 91 camaro with a 305 and im having a very bad vats problem. ive tried adding the resiotors and that does not stop the problem at all. im pretty sure the module is ruined because the only way to get it to start is i have to wait 4 mins after i turn the key and then turn the key agian and then it will start. but that is only during the day at night it will not start at all. i have tried taking the battery off and letting it reset and nothing seems to work. i need to bypass this system any help would be great.
Old Oct 28, 2012 | 07:22 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: vats problem
Only way to do a full VATS bypass is to get a new memcal ( prom ) for the computer with VATS deleted
http://pcmforless.com/index.php?opti...=109&Itemid=29
or wire in one of these to give the fuel enable signal to the computer
http://www.bakerelectronix.com/products_vats/
(Can be found as low as $15 on that auction site)
Both ways require you to bypass the starter relay
Originally Posted by 91camarox
i have tried taking the battery off and letting it reset and nothing seems to work..
Doesn't do anything , if the module doesn't read the key right 1st time it will automatically give 4 min delay
Everytime you turn the key it restarts the 4 timer again
Old Oct 29, 2012 | 04:52 AM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Re: vats problem
do you have a guide for the starter relay part.
Old Oct 29, 2012 | 06:53 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: vats problem
works
https://www.thirdgen.org/forums/tpi/...ay-bypass.html
https://www.thirdgen.org/forums/elec...y-starter.html
https://www.thirdgen.org/forums/elec...mp-bypass.html
Bear in mind that only bypasses the starter part of VATS.
If your VATS module is faulty the engine will still not start because computer will not be getting the fuel enable signal
from the module so the injectors will work
Old Oct 29, 2012 | 04:32 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Re: vats problem
alright so as long as i get that module and bypass the starter i will not have to deal with vats anymore correct. also is a 91 camaro 30hz or 50hz
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
