internal leak in distributor
Old May 4, 2013 | 07:52 PM
89stkformula's Avatar
Car: 1989 formula firebird
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
HAS anyone had this problem before? I am almost positive thats where the oil is coming from.
Old May 4, 2013 | 08:20 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: internal leak in distributor
If your distributor bushings are severely worn you will get oil inside the distributor cap.
Old May 5, 2013 | 10:56 AM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
Taking the cap off today. Just pulled my intake and resealed everything for nothing lol. It looks like the oil is running down my dizzy shaft. I will update later
Old May 5, 2013 | 11:03 AM
Engine: Lb9
Transmission: M20
the easiest way to find a hard to locate oil leak is clean the engine real well and buy oil dye and use a chap black light to find the source. If you do need a new dizzy dont get a cheap chinese one off ebay cardone are decent but I trust the gm icms not aftermarkets.
Old May 5, 2013 | 01:43 PM
Engine: Lb9
Transmission: M20
It could be coming from your oil pressure switch as well.
Old May 5, 2013 | 07:49 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
oil leak found! It took me about an hour and a drive around the block to find the oil leak. It does not leak right away but after a while oil will start spraying out of the plug for the oil pressure sensor don't ask me why it takes so long to leak but it does lol. The oil sprays out good enough to reach the dizzy and make it look like that's the problem. I can't believe I changed my intake gasket for nothing but at least I polished everything while it was off.
Old May 5, 2013 | 07:56 PM
Engine: Lb9
Transmission: M20
Well at least your intake is sealed up good for many years
Old May 7, 2013 | 08:00 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
need more help!
ok Well I took the plug out Teflon taped it and but it back in and it still leaks a little bit. Seems to leak when revving quickly. The plug that's in it has a square end is that normal? I not sure what do now.
Old May 7, 2013 | 08:08 PM
Engine: Lb9
Transmission: M20
Does your car have 2 sensors on a T ?
Old May 7, 2013 | 08:25 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
I have one sensor above the oil filter and there is one plug behind intake under the dizzy.
Old May 7, 2013 | 08:38 PM
Engine: Lb9
Transmission: M20
Like this ?
Old May 7, 2013 | 08:44 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
That one looks like the one above oil filter housing. the plug that's leaking looks like this.
Old May 7, 2013 | 08:49 PM
Engine: Lb9
Transmission: M20
oh just a 1/8 npt plug thats odd its leaking.
Old May 7, 2013 | 08:53 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
yea That's what in the hole for the oil pressure sender not sure if that's the original plug or not. It does not leak all the time just when I am getting on the gas.
Old May 7, 2013 | 08:59 PM
Engine: Lb9
Transmission: M20
a pipe plug is cheap at the hardware store worth a shot.
Old May 7, 2013 | 09:08 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
going to have to something different maybe like a small drain plug something I can put a gasket on.
Old May 9, 2013 | 05:45 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Get a longer plug from the hardware store and wrap it well in teflon, four or five layers. Because that is a tapered fitting, a bolt will not work to plug it unless you had the ability to make one with pipe threads on a lathe.
camarohelp
Sep 22, 2015 03:19 PM
bubbaz28
Sep 18, 2015 02:09 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
scottmoyer
Sep 7, 2015 07:06 PM
Jlanz55
Sep 6, 2015 03:05 PM
