92 camaro 3.1 high beams
Old May 13, 2013 | 12:05 PM
91firebird3.1's Avatar
Car: Firebird
Engine: 3.1
After about 5-10 minutes of driving with my high beams on, all of my lights will start to flicker on and off. I dont see any relays that run in that circuit. Im not sure what direction to go. I've already replaced the switch.
Old May 14, 2013 | 10:52 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: 92 camaro 3.1 high beams
Does tilting the steering column have any effect on your problem?
Do the lights flicker even if you are stopped? And with engine off?
Do you have a voltmeter? You could measure power at different points in the wiring and see where the problem is coming from.
Old May 23, 2013 | 07:58 AM
Car: Firebird
Engine: 3.1
no, the tilt doesnt affect anything, it'll do it regardless of stopped or driving, but it wont do it when the engines off though. when i get the chance this weekend i'll check the voltage readings.
Linson
Aug 21, 2015 02:12 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
BBSDesigns
Aug 11, 2015 07:39 PM
