SGI-5C vs Speedometer for T56
Old Jun 16, 2013 | 09:49 AM
Copperhead's Avatar
So this might just be the last glitch in my 383/T56 swap. I have the SGI-5C box hooked up to the ECM, tried all the various recommended Output 3 and 4 configurations = no speedo. The only Output the speedo moves at all on is Output 1, with switches all off. Speedo reads maybe triple actual speed (120 mph at 2000 rpm in 4th gear with 3.70 gears.)
According to the SGI-5 manual the only application for Output 1 is for a 64,000-250,000 ppm signal; a T56 is 25-40,000, correct? Something's not making sense here. Most of the searches turn up an answer that just doesn't quite apply to my combo.
Any suggestions?
Old Jun 16, 2013 | 12:23 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: SGI-5C vs Speedometer for T56
What year is your T56?
If its a 93 the reluctor ring is different than the 94-02 T56s and requires a different setup than just about every other thread on these forums.
Old Jun 16, 2013 | 11:25 PM
Copperhead's Avatar
I think it may be. What then?
Old Jun 19, 2013 | 01:41 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Post up how you've got it wired, everything.
It sounds like its wired improperly.
Old Jun 19, 2013 | 03:02 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Which ecm are you using?
Old Jun 23, 2013 | 10:56 PM
Copperhead's Avatar
7730 ECM.
12v Power, Ground, Transmission VSS directly to Signal in and Signal Ground. As I said, OUT 1 is the only output that will generate movement on the speedo. All other OUTs read zero, no matter the switch settings. All 4 switches currently set to OFF.
Light on SGI flashes green when moving.
Old Jun 26, 2013 | 11:43 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Switch 3 should be set to ON
You *should* be using out4, though its been about 8 years since I've last setup one of these with the same config you're doing.
Also i'd run a jumper wire over to the main ground from your signal ground connection.
Old Mar 26, 2015 | 01:50 PM
Copperhead's Avatar
TTT. Regrounded as per suggestion. No other outputs will work. I've noticed that occasionally the speedo will drop to zero when driving and the car starts running HORRIBLY. After awhile it will shoot back up to its (incorrect by 250%) reading and run like butter.
Car is parked for another week or two, but thinking about this again for Spring. Do you think the speedo issue is the cause, or a symptom?
Should I buy and try another SGI-5?
Old Mar 26, 2015 | 01:51 PM
Copperhead's Avatar
What kind of different setup?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
