Something fried - Loss of Accessories
Car: 1988 GTA
The wires running to one of my manual cooling fans was routed under the battery and 2 of them were frayed, causing the AC/Heater fuse to blow. I replaced the fuse with a higher rated one and then something fried - and that fuse melted a bit but never burnt out...But the digital dash went out, so did the information center, the heat/AC has no power to it, nor do the power door locks, power windows, or power mirrors.
Other than that the car runs great! But it's a sweat box, and un-drivable without any functioning gauges.
Any ideas what could have fried? Is there a relay or something that could control all these accessories?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fusin’ For A Bruisin’
The most likely cause is:
You blew a fusible link when you installed a too large fuse.
Fusible Links usually look like a one inch plastic rod in line with the wire and are located near the battery or at the starter.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is Sliding On It’s Roof
Happy Racing!
Car: 1988 GTA
Re: Fusin’ For A Bruisin’
This is one of two fusible links by the battery. This one is clearly fried - the plastic tube completely melted. I thought for sure this must be my problem so I cut off the links and temporarily spliced the two wires together - still nothing. Shouldn't it work spliced together like this? Or does it need the link to properly work? Or is it another link by the starter as you said?
Transmission: 765R4
Splice N’ Dice
I don’t see a connection from the pic however
you can use a voltmeter or bulb to find out if the jump is successful.
Happy Racing!
Happy Racing!
Car: 1988 GTA
Re: Something fried - Loss of Accessories
Update on this...Replaced the blown fusible link and everything still dark...BUT...When I turn the key all the way, past ON, right before the ignition, all the lights come on - the full dash and gauges, and the power windows and locks work, fans, AC/heater...all I have to hold it in this position for everything to stay on. Ideas?
Transmission: 765R4
Key To The City
Yes, it sounds like you need to replace the ignition switch.
Happy Racing!
I Never Fight In The Pits . . . . . . . . . My Pit Crew Does That For Me
Happy Racing!
Car: 1988 GTA
Re: Key To The City
Thanks NINA. You feel an electrical short in that fan wire could cause the ignition to go bad?
Car: 1988 GTA
ALSO, since I have the panels removed to get to the fuse panel - there is a rubber hose attached to a wiring harness...not connected to anything...WTF is that doing under the dash?
Transmission: 765R4
Key To The City
Originally Posted by RockShowTrader
…….an electrical short in that fan wire could cause the ignition to go bad?
When you put the overrated fuse in the undue current might have burned a portion on the ignition switch contacts.
…….there is a rubber hose attached to a wiring harness…….
Make sure it’s not being used as a strain relief, then it’s safe to remove.
Happy Racing!
Even Tho I Might Destroy The Car During The Race, At Least It Looks Gorgeous At The Start
RedLeader289
May 28, 2019 01:47 PM
355tpipickup
Sep 28, 2015 05:50 PM
3.8TransAM
Sep 27, 2015 08:37 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
