Wiring experts......I have c207 connector questions
Old Aug 5, 2013 | 07:46 PM
duece's Avatar
Car: 1990 Iroc Z convertible
My 1989 Iroc 350 TPI had the wires cut going to the C207 connector.....the three brown wires are a problem for me
I followed the brown wires(from a spare hacked up 89 tpi under dash harnes also missing the c207 connector)and one wire goes to the fuse box(F/P-Fan-C/H fuse location), one wire goes to the back of the right side(brown)connector(pin 8) behind instrument cluster, and one goes to the ALDL connector(pin C).....
I need to know which of these above brown wires matches up with c207 pin outs A, D. and K.............
Old Aug 5, 2013 | 07:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Wiring experts......I have c207 connector questions
I have those written down but currently away from that information. Will post that up later tonight
Old Aug 5, 2013 | 08:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
One going to c207 pin D is coolant fan fuse from alternator.
Pin A c207 i have as an emissions control wire, not exactly sure what part of the emissions. Have to check service manual for more details
Pin K on c207 is vss signal to ecm
Old Aug 6, 2013 | 12:43 AM
duece's Avatar
Thanks Orr89RocZ ,
So...the brown wire going to the fuse box goes to pin D on the C207 connector ?
....and the brown wire going to the (brown)connector behind the instrument cluster goes to pin K ?
......and the brown wire going to the ALDL connector goes to pin A ?
and need to make sure as i dont want to mess my ecm up.......
Old Aug 6, 2013 | 07:09 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah pretty sure intrument cluster goes to K as that is vss from speedo. Fuse box should have fan fuse and run to D and then out to alternator.
I will double check the aldl. I think is A but not sure. I will look in my service manual.
Old Aug 6, 2013 | 11:10 AM
duece's Avatar
If you can double check in your service manual on all three (pin A, pin D, and pin K) I sure would appreciate it.
Old Aug 6, 2013 | 11:31 PM
duece's Avatar
Orr89RocZ please let me know thanks.........
Old Aug 11, 2013 | 02:51 PM
duece's Avatar
Old Aug 11, 2013 | 03:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Sorry i forgot about this.
Pin A definately comes from AIR pump solenoid to ecm at A2 and also thru c207 to ALDL port pin C. Emissions based so if you do not have smog/air pump for exhaust then wont need this.
K is vss to ecm. Buffer box behind speedo.
D is fan fuse. Thru c207 to alternator and a wire taps off that to feed fan relay
eightsixseven
Dec 16, 2024 01:50 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
