Are these oem connections
Old Aug 19, 2013 | 01:00 PM
C305's Avatar
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
so my car has been running like **** and stalls when put into gear it feels like it was running on 4 cyl, so I disconnected the battery moved some grounds around wasn't sure if aluminium heads were grounding properly, once I connected the battery again I wouldn't get a crank so I start taking a closer look into wiring harness and notice a lot of one wires splitting into 2 and weird connects so I wanted to know if these are stock connections or someone did it,
Attached Thumbnails Are these oem connections-wiring-one.jpg   Are these oem connections-wiring-2.jpg   Are these oem connections-wiring-3.jpg
Old Aug 19, 2013 | 02:13 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Are these oem connections
Was there black tape on them about an inch wide as that would be factory. where are the wires going to? From the pics they look to be on the driver side
Old Aug 19, 2013 | 02:23 PM
C305's Avatar
Car: 91 camaro vert
they were almost covered in blacktape, one goes to a connector on passenger side of tpi plenum there is a little box sensor, one goes to sensor at the front of the intake a temp sensor i think, the other one ill have to look at again.
Old Aug 19, 2013 | 03:18 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
The first two pictures look like factory crimps with the dried-out fabric tape.
The last picture, I cannot pinpoint the wires. What was the connector clipped on? The A/C compressor clutch by any chance?
Lou
$750 L98
Feb 1, 2025 02:25 PM
skinny z
Oct 5, 2015 06:23 PM
customblackbird
Oct 1, 2015 04:30 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
gta892000
Sep 16, 2015 12:37 AM
