82-88 tach fix
Old Aug 21, 2013 | 04:09 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
82-88 tach fix
does anyone know how to fix the tach on a 82-88 Camaro?? I found the write up on the later style but im working on a 86
Old Aug 21, 2013 | 07:26 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: 82-88 tach fix
did you read it?i used it to fix my 1989 tach.
Old Aug 22, 2013 | 07:56 AM
mreld3r's Avatar
Car: 1986 Iroc, 89RS
Engine: 350 tpi, 350 tbi
Transmission: 700r4,700r4
Axle/Gears: 4.10,2.73
Re: 82-88 tach fix
Yes; it will work on MOST model tach's.
I have fixed 3 various year model tach's.
I have an easier way though. When I get home i will take pics.
It involves tracing the wires from the Resistor-Pack to the edge of the board;
where there is MUCH more room to solder a resister.
Just clip the leads of the chip and trace the PCB-traces over to the side.
Scratch the coating off of the trace and solder correct resistor there.
mike
Old Aug 22, 2013 | 07:59 AM
mreld3r's Avatar
Re: 82-88 tach fix
tach board looks different for earlier models; but the same FIX works.
Old Aug 23, 2013 | 08:18 AM
Car: 86 IROC
Engine: 5.0 TPI
Re: 82-88 tach fix
excellent!! its off to the TV repair shop with my cluster..BUT!!! according to my FSM theres a" tach filter" if its bad .what are the symptoms? does anyone know the values? are they available from GM?
Old Aug 24, 2013 | 09:01 AM
mreld3r's Avatar
Re: 82-88 tach fix
Sorry, dont have a clue bout the filter.
All 3 of the ones i fixed were the same problem.
Resister pack
symptoms: tach pegs; or tach is wildly reading high
All 3 were the resistor in my case.
mike
BTW...all 3 were older tachs in my case.
one '89, and 2 '86
Old Dec 19, 2013 | 10:18 AM
gcj280's Avatar
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
Re: 82-88 tach fix
I can sell you one i fixed for $45 + core. I do a professional job and I also replace the capacitors and carbon resistors that can cause a tach to malfunction.
thanks, Greg
Old Dec 19, 2013 | 10:58 AM
austinrods's Avatar
Car: 1988 IROC-Z
Transmission: Automatic
Re: 82-88 tach fix
Originally Posted by gcj280
I can sell you one i fixed for $35 + core. I do a professional job and I also replace the capacitors and carbon resistors that can cause a tach to malfunction.
thanks, Greg
Greg, send me your contact info please.
Thank you Allen
Old Aug 11, 2014 | 02:08 PM
dcurles's Avatar
Re: 82-88 tach fix
thanks, Greg
do you have any more for sale. I need one for an 88, 5.7 car.
Old Aug 11, 2014 | 02:13 PM
dcurles's Avatar
Re: 82-88 tach fix
thanks, Greg
Old Aug 13, 2014 | 07:16 AM
gcj280's Avatar
Car: 1987 Iroc Z
Re: 82-88 tach fix
PM Sent.
Old Aug 25, 2014 | 08:36 AM
88blueiroc's Avatar
Re: 82-88 tach fix
Greg, please send me your contact info, I would like to buy one of your tachs. Thanks
Old Aug 29, 2014 | 07:52 AM
88blueiroc's Avatar
Re: 82-88 tach fix
Greg, please send me a PM with your contact info, I would like to purchase a tach, if you have any left, thanks.
Old Sep 2, 2014 | 08:06 AM
gcj280's Avatar
Car: 1987 Iroc Z
Re: 82-88 tach fix
PM Sent
Old Sep 5, 2014 | 10:18 PM
silverstang84's Avatar
Car: 88 IROC
Re: 82-88 tach fix
Hey guys, I'm also interested in buying a repaired tach. Please message me for info. It's for my 86.
Old Mar 9, 2015 | 09:11 PM
kyle2921's Avatar
Re: 82-88 tach fix
do you have any more tach have 84 Camaro with 350 v-8
Old Mar 11, 2015 | 07:33 AM
gcj280's Avatar
Car: 1987 Iroc Z
Re: 82-88 tach fix
I have temporarily run out of spare tachs. But feel free to send me yours for repair. PM me for details.
thanks, Greg
Old May 12, 2015 | 11:41 AM
Buloushie's Avatar
Car: 1986 Z28 Iroc
Re: 82-88 tach fix
Could you send me your info I would like to get my tach fixed
Old Aug 4, 2015 | 06:53 AM
Animosity86's Avatar
Car: 82 Trans AM Firebird
Engine: JASPER 350
Transmission: Swapped WC T5
Re: 82-88 tach fix
Don't deal with Buloushie, This scum bag ripped me off. Hes going to take the money that he stole from me and buy a part from you. If he even pays you. This is fair warning for anyone dealing with this piece of sh*t.
Old Jan 5, 2017 | 10:15 AM
gcj280's Avatar
Car: 1987 Iroc Z
Send me a pm if you need your tach repaired or text me 318-402-1244.
Thanks, Greg
Old Oct 12, 2017 | 08:37 AM
KCG's Avatar
KCG
Car: 89 IROC
Re: 82-88 tach fix
thanks, Greg
Are you still offering this repair?
Any members here have any feedback from past repairs?
Old Oct 12, 2017 | 11:14 AM
gcj280's Avatar
Car: 1987 Iroc Z
Re: 82-88 tach fix
I have brand new circuit boards for 82-92 camaro tachometers. $50 shipped.
Old Oct 12, 2017 | 11:50 AM
KCG's Avatar
KCG
Car: 89 IROC
Re: 82-88 tach fix
You've created your own replacement board with new components?
Could you post a pic please? I'm sure several would be interested in seeing it.
Old Oct 12, 2017 | 01:24 PM
gcj280's Avatar
Car: 1987 Iroc Z
Re: 82-88 tach fix
Yes I have. I'll post pics soon.
Old Oct 12, 2017 | 03:09 PM
KCG's Avatar
KCG
Car: 89 IROC
Re: 82-88 tach fix
Mine is an '89 and looks like this
Old Oct 13, 2017 | 03:24 PM
gcj280's Avatar
Car: 1987 Iroc Z
Re: 82-88 tach fix
Here is the new one for an 82-89 camaro.
Old Oct 13, 2017 | 04:07 PM
KCG's Avatar
KCG
Car: 89 IROC
Re: 82-88 tach fix
Looks good! Hows the success rate?
Sending pm.
Old Oct 13, 2017 | 08:15 PM
gcj280's Avatar
Car: 1987 Iroc Z
Re: 82-88 tach fix
Sending pm.
I’ve sold about 900 and have only had one or two failures. Most likely due to an accidental short by the installer. I calibrate them on my test bench, but some may need slight adjustment. I build in a potentiometer for fine adjustment. It comes with alifetime warranty.
Old Nov 10, 2017 | 08:30 PM
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
Re: 82-88 tach fix
gcj280, sent PM also
Old Nov 17, 2017 | 06:50 PM
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
Re: 82-88 tach fix
I’ve sold about 20 without a single complaint. I calibrate them on my test bench, but some may need slight adjustment. I build in a potentiometer for fine adjustment. It comes with a 1 year warranty.
Hi Greg, I installed the one you sent me, but had some questions.... PM’d ya
Old Nov 22, 2017 | 02:27 PM
StansFBM's Avatar
Car: 1985 Iroc-Z
Engine: 6.2L LS3
Re: 82-88 tach fix
BTW, circuit board is awesome and got my Tach working for the first time in years...
Old Jul 17, 2018 | 06:46 PM
IROC86CAM's Avatar
Car: 86 IROC
Re: 82-88 tach fix
Are you still fixing tachs? Need 86 fixed
Old Dec 1, 2018 | 01:15 PM
Project1988iroc's Avatar
Re: 82-88 tach fix
mike
what size resistor do I need and where do I put it. My tach pegs out 88 iroc
Old Oct 15, 2019 | 08:54 AM
Jeepwrangler's Avatar
Re: 82-88 tach fix
I’ve sold about 100 without a single complaint. I calibrate them on my test bench, but some may need slight adjustment. I build in a potentiometer for fine adjustment. It comes with lifetime warranty.
Could you seed me your contact information I need a tac or have mine fixed it's a 1987 irock 5.7L thank you
Old Oct 16, 2019 | 08:24 AM
gcj280's Avatar
Car: 1987 Iroc Z
Re: 82-88 tach fix
Sure thing.
Greg Johnson 318-402-1244
website: www.cajuntachshop.com
email: cajuntachshop@yahoo.com
Thanks! Greg
Old Jan 20, 2020 | 01:15 PM
shuffZ's Avatar
Re: 82-88 tach fix
Not to dig up an old thread but I'm having problems with my 83 Z28 tach. I have two clusters and both of them peg the tach if i plug in the white wire at the HEI coil. Original cluster was a mess so i ordered a used one off ebay and everything else works now. But same results with tach. Seller says tach was confirmed working.... Sounds like this is the fix. I checked out your website and the replacement boards look awesome. The car was originally cross fire, now carb 350 with HEI coil in cap distributor if that changes anything.
Old Jan 22, 2020 | 11:00 AM
gcj280's Avatar
Car: 1987 Iroc Z
Re: 82-88 tach fix
Hi ShuffZ. Thanks! This is a very common problem with these tachometers unfortunately. My replacement circuit board should fix your tachs and they come with a lifetime warranty. I will give you a discount for 2 boards or we can work out a trade deal if you don't want both tachs. Just let me know. Give me a call or text when you are ready.
Thanks! Greg
318-402-1244
Old Feb 16, 2020 | 01:38 PM
earthwormtimmy's Avatar
Re: 82-88 tach fix
Hi, I've had trouble the rev counter, the other gauges jumping and live in the UK. Would you / do you ship to UK?
Old Feb 18, 2020 | 01:43 PM
gcj280's Avatar
Car: 1987 Iroc Z
Re: 82-88 tach fix
Absolutely, I can ship USPS first class, but it takes about a month at least. If you want to pay a little more for shipping, I can do Priority International. (I prefer it btw)
Thanks! Greg
Old Feb 18, 2020 | 02:11 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Re: 82-88 tach fix
For anyone who may be hesitating to pick up the Cajun Tach Shop board, don't.
Put one in my car, and am SUPER pleased to not only have my tach be correct for the first time since I've owned it in 13 years, but it was also dead accurate right out of the box.
@gcj280
Do you have any intentions of expanding to repairs/calibrations of other gauges on these cars or even others?
Old Mar 29, 2020 | 05:59 AM
Geoff Stellini's Avatar
Re: 82-88 tach fix
Hi could you provide me with a quote for a board for my 1988 Camaro as I am in Australia, Melbourne.
Geoff
Old Aug 15, 2025 | 11:10 AM
  #42
cardene's Avatar
Re: 82-88 tach fix
thanks, Greg
do you still work on the tach circuit boards? I need one also temp gauge
Old Aug 15, 2025 | 04:42 PM
  #43
gcj280's Avatar
Car: 1987 Iroc Z
Re: 82-88 tach fix
Hi. I sell brand new boards at www.cajuntachshop.com
jeeps2creep
Oct 12, 2021 05:07 PM
1991tealRSt-topGuy
Jan 24, 2002 07:05 PM
