Car not charging...?
Old Dec 17, 2013 | 01:15 PM
TipTricky's Avatar
Car: 1991 Chevy Camaro Z28
Engine: 5.7lt TPI L98
Axle/Gears: Drum Brakes, Not Sure Gears
So my 91 z28 is not charging. Now i know what you are thinking probably something along the lines of "how hard could the be to figure out what a tard" but just hold on a second and let me explain. Car has a brand new battery, altinator has tested good at autozone and oreilleys, possitive cable is 0.001ohms so no resistance there, grounds are clean and tight. I still think its the altenator because when running the voltage drops about .01 ever couple of seconds from 11.8 and dropping
Old Dec 17, 2013 | 02:47 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Car not charging...?
Sometimes you can get a "dud" battery brand new, happened to me once. Try swapping it again if you have another car or something you can trade batteries with, if it still doesn't charge then you have fully ruled out the battery.
Old Dec 17, 2013 | 02:49 PM
TipTricky's Avatar
Battery charges from a charger and passes a load test im pretty sure its good
Old Dec 17, 2013 | 02:53 PM
Car: 1983 Z28
Fair enough. Sounds like an alternator problem is the only other thing it could be.
Old Dec 17, 2013 | 02:54 PM
TipTricky's Avatar
So i guess i should cave and go buy a new one then... yay me haha
Old Dec 17, 2013 | 02:58 PM
Car: 1983 Z28
Yeah...
Maybe it has the wrong one on it or something, if someone replaced it recently. (i.e. put one for a non-A/C car on it instead of one for an A/C car). Who knows.
Oh the fun of having an old car!!
Old Dec 17, 2013 | 03:02 PM
TipTricky's Avatar
Yeah im replacing most things any way was hoping not to have to replace that to but oh well. The best part of owning this old car is the previous owners were definitley not mechanics so just about all the wire harnes clips are broken. Any ideas of where to get a engine harness?
Old Dec 17, 2013 | 03:05 PM
Car: 1983 Z28
Lovely. I'd say your local pull-a-part/junkyard/etc if you wanna get one cheap. Otherwise Ebay and various places online have them used and new or NOS.
Old Dec 17, 2013 | 03:07 PM
TipTricky's Avatar
I would like a new one and picknpull will most likely never have a l98 tuned port injected anything in there yards around here haha
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
