Wiper motor issue
Old Dec 22, 2013 | 04:46 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Wiper motor issue
Finally started tackling the wiper motor, bolted it up, used a connector from the parts car harness that goes to the connector from the switch, found the wires that were cut under the dash and at the firewall, I've been reading up on threads and it appears I should have 12 volts going to the purple wire at the firewall right? Well I hooked that up to the middle terminal on the L-shaped plug port on the wiper motor and all I get is clicking when on the high position. I even put power directly from the battery to the terminal and all I get is clicking. Is the motor bad? I disconnected the wiper arm to make sure it wasn't froze. What gives? I already have another wiper motor coming to my shop just in case, but is it safe to assume its bad? I've never seen it work, it came in box along with other stuff that got taken out!
Old Dec 23, 2013 | 07:39 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Purple Rein
With the wiper unit unplugged, key in the ACCY position, and the wiper switch in the HI position, use your voltmeter to probe the pink, dark green, gray, and purple wires.
Which wires do you have power on?
Happy Racing!
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
Old Dec 23, 2013 | 08:18 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Originally Posted by NINÅ
With the wiper unit unplugged, key in the ACCY position, and the wiper switch in the HI position, use your voltmeter to probe the pink, dark green, gray, and purple wires. Which wires do you have power on? ◙◙◙◙◙◙◙◙◙◙◙◙◙◙◙ Happy Racing! ◙◙◙◙◙◙◙◙◙◙◙◙◙◙◙ I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
The only ones I hooked up so far were the purple and gray one, I get 11.89 at the purple one
Old Dec 23, 2013 | 08:45 AM
NINÅ's Avatar
Transmission: 765R4
Purple Rein
With the wiper unit unplugged, key in the ACCY position, and the wiper switch in the HI position, you need to have power on the pink wire, and the purple wire.
Also, when the connector is hooked up, does the washer work?
Happy Racing!
Old Dec 23, 2013 | 12:19 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
With the wiper unit unplugged, key in the ACCY position, and the wiper switch in the HI position, you need to have power on the pink wire and the purple wire, but NOT the gray wire. Also, when the connector is hooked up, does the washer work? ◙◙◙◙◙◙◙◙◙◙◙◙◙◙◙ Happy Racing! ◙◙◙◙◙◙◙◙◙◙◙◙◙◙◙ I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
I got no power to the gray wire, only the purple one. The pink one isn't hooked up yet. I don't have a connector for it. The washer pump isn't plugged in as I don't have the reservoir
Old Dec 23, 2013 | 12:58 PM
NINÅ's Avatar
Transmission: 765R4
Purple Rein
OK, progress.
You need to have power on the
gray wire.
You can start your probe at the stalk to see if you have power on the
gray wire at that location when the stalk is in the HI Wipers position with the key in the ACC position, and if you do, see if it’s getting thru what we call C100 which is located near the left front of the dash below the relay bracket.
Happy Racing!
Old Dec 23, 2013 | 01:59 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
OK, progress. You need to have power on the gray wire. You can start your probe at the stalk to see if you have power on the gray wire at that location when the stalk is in the HI Wipers position with the key in the ACC position, and if you do, see if it’s getting thru what we call C100 which is located near the left front of the dash below the relay bracket. ◙◙◙◙◙◙◙◙◙◙◙◙◙◙◙ Happy Racing! ◙◙◙◙◙◙◙◙◙◙◙◙◙◙◙ I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
But you just said I shouldn't have power there? Maybe I spliced the wrong gray wire, I'll double check
Old Dec 23, 2013 | 04:05 PM
NINÅ's Avatar
Transmission: 765R4
Purple Rein
Whoops sorry about the typo.
As I stated in post #6 you need power on the
gray wire for model year 1984.
There are changes from year to year changing the status of the
gray wire.
Happy Racing!
Old Dec 23, 2013 | 04:44 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Whoops sorry about the typo. As I stated in post #6 you need power on the gray wire for model year 1984. There are changes from year to year changing the status of the gray wire. ◙◙◙◙◙◙◙◙◙◙◙◙◙◙◙ Happy Racing! ◙◙◙◙◙◙◙◙◙◙◙◙◙◙◙ I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
What terminal on the motor does the power wire go to?
Old Dec 23, 2013 | 09:45 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Wiper motor issue
These might help:
Standard
Pulse
Old Dec 23, 2013 | 11:02 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
These might help: Standard Pulse
Does anyone have the a picture of the actual connector going into the wiper motor?
Old Dec 29, 2013 | 12:45 PM
flash2042's Avatar
Car: 83 Z28
Engine: LG4
looking for one myself. subscribing to this thread to keep an eye on it.
Frozer!!!
Jan 19, 2024 04:55 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
slade5612
Aug 11, 2015 07:19 PM
