85 berlinetta vss.
Car: 1985 Camaro Berlinetta
Engine: Rebuilt 350
85 berlinetta vss.
I own an 85 berlinetta with the digital dash. I've read a lot if the other posts on the digital dash but I can get a straight answer on what the vss links like. Does anyone have a picture?
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Re: 85 berlinetta vss.
What is it you are looking for? I have a 1984 Berlinetta with digital dash and have never heard of "vss links" If you need a picture of the digital cluster I can help out.
Engine: Rebuilt 350
Oops type but I need a pic of the vss. Some ppl has said it was wireless and another shows it as what looks like a regular vss.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Some years had a speedo cable drive to the IP and a box there supplied the VSS signal
Some years have a VSS in the trans and 2 wires to the IP or ECM
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Wireless that's awesome , it will be cable driven in sure in 85 and built into the speedometer cluster. The non digital speedometers used a external vss optical buffer clipped onto the cluster a small yellow of green little box.
Engine: Rebuilt 350
well mines digital is there anyway to tell cause ive been using my phones gps as a speedometer but thank you guys for your replies.
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Here's a pic of the Berlinetta Vehicle Speed Sensor,... Its' mounted in the tranny tailshaft.
If your Berlinetta Digital readout is ALWAYS dark, the cluster needs to be replaced. If the Digital readout always shows '0' miles an hour than either the VSS is bad, the speedo gears are bad, or the VSS Buffer ( plastic yellow case ) is bad.
Elephantismo
Feb 13, 2019 12:51 AM
Linson
Oct 1, 2015 09:50 PM
manifoldsrme
Sep 17, 2015 11:40 PM
