engine revs way up wherever i turn it on
Old Mar 9, 2014 | 01:58 PM
crashcrtr's Avatar
Car: 1992 Chevy Camaro z28
Hi guys,
So I just encountered this problem for the first time today and I can't figure out what the cause is. When I turn my car on the revs fly way up past the end of the gauge. I can't decipher any problem with the throttle plate or linkage, theyre sitting as they should be. This leave me thinking its the throttle positioning sensor? I tried to probe it with my voltmeter and am not getting any reading. Do you guys think this sounds like a tps problem? Could it be something else?
Old Mar 9, 2014 | 02:11 PM
M.Leblanc's Avatar
Car: 1986 Camaro IROC-Z
Transmission: Stage 2, 700R-4, vette servo and TC
Re: engine revs way up wherever i turn it on
Given you are reading the TPS voltage properly, getting nothing seems a little improbable. Make sure you are reading the right ports and if your voltage is all skew and you cant position the TPS in the optimum range, start there.
Old Mar 9, 2014 | 02:42 PM
crashcrtr's Avatar
I have fiddled and retested. Still no results.
https://www.thirdgen.org/forums/tbi/...do-i-test.html
According to this thread no voltage confirms a dead tps.
Old Mar 9, 2014 | 02:56 PM
M.Leblanc's Avatar
well start from there then, if youre getting nothing. TPS's are super cheap anyways
Old Mar 9, 2014 | 03:15 PM
crashcrtr's Avatar
I dunno if a hundred buck counts as super cheap, but I guess when you need the part you need the part..
Old Mar 9, 2014 | 04:07 PM
Zeifer's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 408 LSx
Transmission: T56 Magnum
Axle/Gears: 3.73 10-Bolt Detroit TrueTrac
Mine was like 125 from the dealer. I could have got one from Advance for 80 but I decided to go with the Delco part.
My car was idling at 1400 before I changed mine. Your car is redlining, or is it just the gauge going to 7k?
Old Mar 9, 2014 | 04:28 PM
crashcrtr's Avatar
I think its close to redline, it revs really high and the needs is hitting the tack. But If I hit the gas pedal it still revs more. I didn't test this very much, worried about doing damage at that many revs. I just ordered a new part of napa's website for $90, they're closed today so hopefully they overnight it tomorrow and I can let you all know where I'm at on Tuesday. Thanks again!
Old Mar 9, 2014 | 10:44 PM
Zeifer's Avatar
Engine: 408 LSx
Hope that fixes your issue. Does it change if you unplug your TPS?
Old Mar 9, 2014 | 10:46 PM
crashcrtr's Avatar
Sort of, when I tried with the tps unplugged it ran really rough but near the right rpms for a few seconds before the rpms shot back up.
Old Mar 10, 2014 | 05:46 AM
Zeifer's Avatar
Engine: 408 LSx
What SES codes are you getting?
Old Mar 11, 2014 | 10:36 PM
transaero's Avatar
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
This may sound dumb, but check and make sure the gas pedal isn't caught on the under dash panel. That happened to me and left me scratching my head for a bit.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Andrew6.688
Dec 13, 2015 10:59 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
