No power
No power
Hello yall I think I blew my camaro up!! But I hope not.. Hooked starter up then battery as soon as I hooked batt up starter spun 😞 so I disconnected everything but now no power at all... Im hoping i blew the main fuse. So I'm looking for the main fuse where is that bitch??? Help help!!! 91 camaro 3.1 any help would be great
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
No Power Thus Hour
There is no ‘main fuse’.
You apparently misconnected something.
The purple wire goes to the S terminal.
The M terminal gets the +
batt cable, and fusible links.
Make sure the starter goes to a clean ground.
Happy Racing !
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Happy Racing !
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: No power
Check that first.
It's possible you blew the main fuesable link going up from the starter, that'll kill all power to the car beyond the starter.
Re: No power
So did you hook the starter cable back up to the right terminal now? The diagram I see doesn't show a purple wire. It shows the fusible links being in the red wire. Just trace the wires from your solenoid and you should find the links.
Re: No power
yes I believe I have it hooked up proper now would the fusable links be white round things around the red wires? And when I go to replace are those spliced into place?
Re: No power
Alright guys got the fusable links replaced and have power! Big step in the right direction. So now I have a vehicle that cranks but no start. Fuel pump primes. So where should I go next? Ideas hints?
Car: 1984 Trans Am
Re: No power
You need to check your fuel pressure, just because the pump primes doesn't mean it's putting out enough pressure.
