c100 power distribution question
Old Aug 29, 2014 | 04:36 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Axle/Gears: ls1 rear with 3.23
85 iroc c100 plug. I know these connect to starter. Im trying to find out what this red wire was connected too. It splits off one of the main power wires coming from starter to c100
Old Aug 29, 2014 | 04:52 PM
Joe Tag's Avatar
Re: c100 power distribution question
Looks like your fusible links, go to the same post on the starter as the positive cable from the battery.
Old Aug 29, 2014 | 05:47 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
yea they do but one link has that red wire coming out and its cut. i can't think of anything that would be getting power directly from that link instead of the fuse box
Old Aug 29, 2014 | 06:01 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
two fusible links one has this red wire connected.
ur saying that goes to starter too?
Old Aug 29, 2014 | 06:11 PM
Joe Tag's Avatar
There are 3 links that go to the starter. One is the two wires into one loop and there is another single. I would get another fusible link and replace the cut one. You may be able to crimp a loop on it but I doubt you can get one with a large enough hole for the bolt and small enough connector for the link. Any parts store will have them. Should be marked with a number 1.6 or so which is a measurement in sq mm not amps.
Old Aug 29, 2014 | 06:45 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
so i should put a fusible link on the wire i highlighted green and connect to starter?
Old Aug 29, 2014 | 07:00 PM
Joe Tag's Avatar
No you should not. I thought that was separate from the two wires it's connected to. There should be another one that goes to the starter. I think that one goes to the blower motor high speed relay.
Old Aug 29, 2014 | 07:17 PM
Joe Tag's Avatar
Just went to my car to make sure I remembered correctly, but two loops, three links. 86 Z, but an 85 harness. Should be the same on yours. Can't tell you for sure where that one goes, but the length leads me to believe the blower relay.
Old Aug 29, 2014 | 09:36 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Thanks joe ur helpin me a lot. ill keep you posted on the swap
Old Aug 29, 2014 | 09:53 PM
Joe Tag's Avatar
No problem. Glad to help out.
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Bert87
Aug 23, 2015 03:50 PM
redmaroz
Aug 16, 2015 11:40 PM
