dome light
Old Jan 3, 2015 | 10:33 PM
powder white's Avatar
Car: 82 Z28
Engine: 350 LT1
dome light
my dome light and my door lights dont come on with the door open or closed
lower lights come on only if you turn the switch but no dome light or mirror light
Old Jan 5, 2015 | 01:43 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: dome light
Unscrew the door pins and then screw them back in place. They might not be making a good ground and turning them a few times might help. If it doesn't - pull them out and clean the terminals and wiring,.. then screw them back in. ( It's a bad spot for keeping a "clean" contact point !!! )
The courtesy "dome" light should work with the doors or the ****...... My guess is a dead bulb.
Old Jan 5, 2015 | 09:06 PM
Car: 82 Z28
Engine: 350 LT1
Re: dome light
ill try it bulb was good no power to dome or doors
Old Jan 5, 2015 | 09:12 PM
John in RI's Avatar
Re: dome light
Courtesy lights should have power at all times. They are operated/controlled by a "switched ground". This ground can come from the headlight switch or the door jam pins.
I can't remember if the factory lighted mirror light worked with the other courtesy lights,..... or only when the buttons are pressed. ( I always custom wire them to work with rest of the courtesy lights AND on demand )
Old Jun 16, 2015 | 08:29 PM
Car: 82 Z28
Engine: 350 LT1
Re: dome light
can you show or tell me how do do this
Old Aug 13, 2015 | 07:19 PM
Car: 82 Z28
Engine: 350 LT1
Re: dome light
hey there john can you show me how to custom wire my dome lights and the courtesty lights thank you sir
Old Aug 15, 2015 | 08:05 PM
John in RI's Avatar
Re: dome light
The courtesy lights and the DOME light should be wired to work at the same time from the factory. If they don't - then you need to figure out why because something is wrong.
ORANGE wire = power at all times.
WHITE wire = switched ground.
Connect the ORANGE wire from the dome to the ORANGE wireto the courtsy,.......
Connect the WHITE wire from the dome to the WHITE wite to the courtsy,.......
Then they will operate at the same time.
Old Dec 29, 2015 | 08:58 PM
Car: 82 Z28
Engine: 350 LT1
Re: dome light
thank you sir i will do this
383cam
Sep 9, 2015 06:01 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
