Custom TPI Wiring Harness
Old Feb 2, 2015 | 12:12 PM
86Base's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 383 Stroker
Transmission: stage 2 2004r
Axle/Gears: 3.55
Is there anyone that can make or know someone/company that makes custom TPI speed density Harnesses for swaps?
Old Feb 2, 2015 | 12:16 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Custom TPI Wiring Harness
Fuel injection connection, the bad it's a stand alone so you can pass it through the stock hole under the pass fender
Old Feb 2, 2015 | 12:20 PM
Engine: Lb9
Transmission: M20
http://www.fuelinjectionconnection.com
Old Feb 2, 2015 | 12:27 PM
86Base's Avatar
Engine: 383 Stroker
Axle/Gears: 3.55
Thanks, I have sent an email to them and waiting for a response. im currently talking with AFI about a custom one. im just seeing whats available out there
Old Feb 2, 2015 | 12:31 PM
Engine: Lb9
Transmission: M20
I have had one from afi and was not impressed with the quality. The fuel injection connection looks better than painless wiring ones. You can allways use the pass through plug from your 2.8l harness drill a hole through it and silicone it after the harness is installed through the pass through connecter.
Old Feb 2, 2015 | 02:28 PM
86Base's Avatar
Engine: 383 Stroker
Axle/Gears: 3.55
what was bad about the AFI?
Old Feb 3, 2015 | 12:45 PM
Engine: Lb9
Transmission: M20
What I didn't like about the afi harness is they used a Bosch style 5 wire relay and spliced it into the harness insteal of having the tooling to crip on the connecters. There was not a afo fuse block for the injector power wires. The Bosch style relay is great but I would prefer a gm style weather proof one for something as important as a fuel pump.
Old Feb 5, 2015 | 09:44 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Pocket, member on TGO here, will also make one from scratch for you. Super high-quality. You just got to sweet talk him and tell him sweet nothings...
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
armybyrd
Dec 5, 2015 09:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
Sanjay
Aug 12, 2015 03:41 PM
