1990 iroc Z pin location
Ok so I bought a VATS bypass module from bakerelectronix and it says that I need to find fuel enable pin on my So me and and my dad pulled ECM out and pulled out connectors on the back and we had 3 connectors colored light blue and one 2 of them one side was light blue the other side was gray and we looked and looked but couldn't find any connector that was labeled F at all much less find pin F10 I need help where is my f10 pin/connector and if I don't have one which one is the fuel enable pin? An where is it? Please help and thank you and my car has the 5.7 TPI
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: 1990 iroc Z pin location
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
See where the pic shows F1? 10 spots to the right is F10.
If not then the second link is the wiring diagram and it shouldn't be very hard to find what you are looking for. Just trace the wires.
Would be much easier if you would just buy the book for the car...
We have the book for the car.... As well as 3 diagrams iv been suggested and they all say the same thing F10 well that's fine and dandy and I'd be glad to count over like u suggested but you see none of the connectors are labled F I have A's, B's, C's, and D's but nothing further
If you cant find the fuel enable wire with the wiring diagrams in front of you, then maybe you shouldn't be working on the car...
[QUOTE=willexoIX;5876171]If you cant find the fuel enable wire with the wiring diagrams in front of you, then maybe you shouldn't be working on the car...[/QUOTE
Ok.... If you so smart where is itt suppose to be describe to me how u would get to the F10 (fuel enable wire)
Clearly you don't have a pin F10. Therefore you need to follow the wiring diagram to find your fuel enable wire.
I'm not going to give you the answer you want, otherwise you will not learn how to read the wiring diagram.
Yes I am a smart guy, I'm an Electronics Engineer smartass.
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
We can't help you, if you won't help yourself.
Look up Austin Thirdgen. There are lots of helpful diagrams there.
Ok everyone chill the **** out ok no need for this to get violent ok look I'm more than happy to search somemore for the fuel enable wire but what I need u guys to do is tell me the general location I'm looking if the wiring schematics and I don't see anything pertaining to fuel enable wire so where is it? Is it part of the cluster that hooks to the ECM or...? Where a general location for me to search
Car: 91 z28
Transmission: 4L60e
http://www.austinthirdgen.org/mkport...m_pass-key.jpg
C207 post #1
https://www.thirdgen.org/forums/ltx-...formation.html
C207 post #1
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
If you get tired of the headache, like I did, I would be willing to spend the extra $ 30.00 for a basic VATS removal and either send back what you have or sell it on EBay
Talk to this man. A much better choice and he can add a few nice extra performance enhancing features if you want.=
https://www.thirdgen.org/forums/elec...ing-tuned.html
I would at least get the extras I did.
Dialed_In
Aug 20, 2015 01:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
