Wiring advise needed Maf engine 91 camaro
Old Mar 14, 2015 | 12:26 PM
rocn7roc's Avatar
Installing 86 Corvette maf engine that has vats which I will have the prom delete that .The car is a 91 so it has the vats system and the harness I am using is an 87 Camaro maf that has no wire in harness for vats, Can anyone tell me how and if i need to wire from the ign to the computer, I am old retired guy and think to much sometimes.Any imput would be appreciated Thanks Mike
Old Mar 17, 2015 | 06:28 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Wiring advise needed Maf engine 91 camaro
Sure, sell the harnesses you have and run a 90-92 TPI harness with no MAF
Old Mar 17, 2015 | 09:01 AM
rocn7roc's Avatar
Want the maf have cam and headers, I just meant vats signal wire and the vats will be deleted in the prom.
Old Mar 17, 2015 | 11:05 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Like he said, you are asking for trouble trying to bolt an '87 harness to a '91.
It can be done but major problems.
Old Mar 17, 2015 | 12:18 PM
Pocket's Avatar
Car: 91 Trans Am
Running a MAF wont get around needing a tune which is what it sounds like you're trying to do
To run an older TPI harness in your 91, you'll have to repin the C100/C207/C221 on the 87 harness to match the 91's dash harness. IMHO, its easier to sell it and start with a 90-92 harness
If the 87 computer didnt have VATS and your 91 does, then the old ECM wont care, itll fire anyways. VATS will only remain in the starter enable relay, which will work like stock as long as your key matches the VATS module. Since it sounds like its just and engine swap, not a column swap, thats still kosher
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
armybyrd
Dec 5, 2015 09:22 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
