Another vats issue
Old May 7, 2015 | 08:31 AM
Ptruck21's Avatar
Another vats issue
I have a 91 tbi 305 car. The vats system is throwing a fit. I have tried all kinds of things via info on this forum. Has anyone tried using an aftermarket alarm bypass to fix the issue?
Old May 7, 2015 | 09:10 AM
concorde01's Avatar
Re: Another vats issue
what is it doing?
Old May 7, 2015 | 09:16 AM
Ptruck21's Avatar
Vats isnt allowing injector to pulse. Bypassed the starter relay, new igntion tumbler, starter. You name it, ive tried it lol.
Old May 7, 2015 | 09:20 AM
concorde01's Avatar
what i did because my car can with the wrong type ignition is under the hood by the relays on driver side firewall is the wiring harness. i jumped the small orange wire to the large pink wire. no mine works. i didnt cut them just removed enough shielding frome them to twist a wire end around them. then taped the ends. but thats just me. mine was a backet case
Old May 7, 2015 | 09:27 AM
Ptruck21's Avatar
Ill run out and look but i dont remeber seeing a pink wire
Old May 7, 2015 | 09:29 AM
concorde01's Avatar
its in the big wire loom. might have to dig for them. i did. it worked on mine
Old May 7, 2015 | 09:32 AM
Ptruck21's Avatar
Ok found the pink. Which orange wire?off the fuel pump relay?
Old May 7, 2015 | 09:35 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
That'll fix it
Old May 7, 2015 | 09:36 AM
concorde01's Avatar
i only found one orange wire in mine but it got my pump going and injectors. but like i said. thats just my car. might not on urs. who knows
Old May 7, 2015 | 09:38 AM
Ptruck21's Avatar
I wish lol. Been beating my head against the wall for 3 days now. Im a locomotive mechanic, they are just 2 stroke diesels. Nothing to them
Old May 7, 2015 | 09:41 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Oil pressure switch has to detect pressure before it enables the injector pulse
Old May 7, 2015 | 09:43 AM
Ptruck21's Avatar
Ya when cranking im getting oil pressure
Old May 7, 2015 | 09:47 AM
Ptruck21's Avatar
Back to my orignal question though. Has anyone used a remote starter bypass module to get it running
Old May 7, 2015 | 01:55 PM
Ptruck21's Avatar
Or know anyone near st louis,mo that will flash the pcm
Old May 7, 2015 | 07:46 PM
sabien's Avatar
Car: 91 Camaro
Engine: 355 Carb
Transmission: 5 speed
Axle/Gears: 342 Posi
You do not need a "remote starter bypass module" to get around the vats. The stereo shops that install remote starters use a resistor to jumper the vats system. You can buy a pack of about 14 that covers all the GM vats systems. Measure your key chip resistance with an ohm meter to find out which resistor you will need. After that ,take off the drivers side knee panel under the steering column. Locate the 2 white wires inside of an orange insulating sheathe. There will be a small white plastic plug connector at the end. Cut the plug end closest to the steering column and solder the resistor across those 2 wires on that end. This should solve your problem. Costs about $8 and 15 minutes of your time.
Old May 8, 2015 | 07:28 PM
backyardwrench's Avatar
Does your car have a distributor? Replace the ignition module, that is what sends signal to injectors to pulse.
Old May 8, 2015 | 07:35 PM
I tried that on the vehicle I'm working on. It kept the check engine light and the air bag light on. I think I'm lucky that I had it air bags disabled.
My vehicle has a distributor in it. If it would have coil packs that might work.
Old May 8, 2015 | 11:50 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Here's something to consider =
https://www.thirdgen.org/forums/elec...ing-tuned.html
Old May 11, 2015 | 03:06 PM
Ptruck21's Avatar
Where is this tuned performance located?
Old May 11, 2015 | 03:11 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
In Colorado,
You send him your chip, he does the magic, and send it back. It took a week to do mine.
Tuned is great, Check him out.
Old May 12, 2015 | 01:18 AM
Engine: TBI,5.0
Yes, I wish I had used Tuned Performance in the beginning. It would have saved me a ton of trouble.
Old May 12, 2015 | 10:13 AM
Ptruck21's Avatar
Anyone know anyone near st Louis?
Old May 12, 2015 | 12:02 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Send me a pm if you want to go with a prom with vats disabled !
bbsr72
Sep 27, 2015 05:55 AM
TheTraut88
Sep 11, 2015 05:16 AM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
studebaker60
Sep 7, 2015 12:36 PM
