Think I Found A Way To Disable VATS
Old Dec 19, 2001 | 07:59 PM
92RSB4C's Avatar
After being stuck in a parking lot for 5 minutes, I finally got tired of the VATS system, so I'm trying to find a good way to disable it.
I still want it to shut down the car, so I don't want to totally take it out.
My plan is to disconnect it where it joins together under the dash, and put a resistor there. (1470 ohms for me) I want to find a connector of the same type(male) from a junkyard and wire in a resistor to it, to form a loop.
Then, if I don't want the car to be started, I can just pull the VATS fuse from the fuse block.
Any suggestions?
Old Dec 19, 2001 | 08:27 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Might be the wrong forum for this
Hit the wrong one?
Old Dec 19, 2001 | 08:47 PM
FbodyX2's Avatar
Moving to the Electronics board.
Old Dec 19, 2001 | 09:58 PM
joker37's Avatar
Car: 1989 Iroc
Engine: 5.7
Transmission: TH700R4
it should work. if you do this, you can even change the lock cylinder to use just regular keys. but if you forget to take out the resistor, the car is gone in 60's like any other.
Joker
Old Dec 19, 2001 | 10:10 PM
Lov2xlr8's Avatar
I have found that if you take the black wire with the yellow stripe on it going to the vats module, and give it a ground. This will bypass it. if you still want the protection just wire up a switch to it. Thus providing a switched gound to the vats.
Old Dec 20, 2001 | 01:38 PM
KlayBuRn's Avatar
Just burn a custom chip with VATS disabled...
Old Dec 20, 2001 | 09:26 PM
92RSB4C's Avatar
Now I can't decide if I want to make a resistor plug or a ground switch.
The resistor plug is a simple strait forward device and the ground switch would take more effort but I would have it just right there.
I think I'll go with the resistor plug because I won't really use the VATS all that much anyway. And I can go back to stock without any splices.
Old Dec 22, 2001 | 02:15 PM
92RSB4C's Avatar
Well, I put the resistor plug in and it works like a charm! I got an Auto X Ray EZ Link for Christmas so, I'm really, really happy now.
Old Apr 22, 2003 | 11:41 PM
JediNemesis's Avatar
I need to disable the VATS on my 89 Camaro RS. This is the wiring scheme. I know the colors are right, and I think I have the functions of the wires right, but I'm not sure. I am wondering which wire that I should ground (as you can see I don't have a black and yellow wire). Also, am I supposed to ground the wire going to the VATS box or should I ground the end coming from it or both?
Thank you very much,
Will
Orange 12v 10a from vats fuse on fuse block
Lt grey (white?) – blk resistor pellet
Gray Security light
Blue ECM Fuel Enable Control, ground going to the ECM
Green Starter Enable Relay Control – relay behind lh kick panel
provides ground to relay
Purple – ylw Resistor Pellot
Black – white Ground
Pink – black 12v 10a from ECM fuse
pjsparts
Oct 29, 2025 06:39 PM
bbsr72
Sep 27, 2015 05:55 AM
383cam
Sep 9, 2015 06:01 AM
studebaker60
Sep 7, 2015 12:36 PM
rudolphschenker
Sep 4, 2015 02:41 AM
