Is this a piece of sectioned "fusible link" ?
Old Nov 22, 2015 | 09:47 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
This is on a dash i'm swapping because mines cracked by the radio.
Dash is from an 87 5.0 Tpi. Ok this solid purple wire Pins at the B-4 on the bulk connector on the drivers side firewall, My poor research seems to be the 9th injector power? not sure and chip is burned for 9th delete. But, Why is this black section pieced in? is it a fusible link? I thank you for any help..
Old Nov 22, 2015 | 10:47 PM
mjdavis68's Avatar
Re: Is this a piece of sectioned "fusible link" ?
I found that PURPLE is for the ignition, so i wonder why it's there?
Old Nov 23, 2015 | 12:55 AM
Twin_Turbo's Avatar
Looks like just a wire repair, not a PN switch bypass.
Old Nov 23, 2015 | 08:55 AM
-srs-'s Avatar
Car: 1991 Z28 Vert
The PO may have had an alarm installed. Either way, I hate butt splices.
Old Nov 23, 2015 | 12:13 PM
mjdavis68's Avatar
I think your absolutely right on the alarm theory. It would be the remote start most likely.
Old Nov 23, 2015 | 03:19 PM
Twin_Turbo's Avatar
solder and heat shrink it or use those combo solder shrink sleeve thnings, they work well.
Old Nov 23, 2015 | 05:13 PM
mjdavis68's Avatar
Just picked up a butane soldering kit with heat shrink and wire loom.
Thanks.
Old Nov 25, 2015 | 08:52 AM
Pocket's Avatar
Car: 91 Trans Am
B4 is starter solenoid from the IGN switch. Looks like an alarm system or remote start was installed then removed. Short section of 12ga added to make up the difference
John Hagan
Dec 16, 2024 07:39 PM
zuuhlst/a
Exterior Parts Wanted
Feb 1, 2016 05:52 PM
KITTClone
Nov 11, 2015 07:58 PM
anesthes
Oct 15, 2015 07:44 AM
Thornburg
Oct 3, 2015 10:12 PM
