No dash lights or radio
Old Jan 16, 2016 | 07:35 PM
Paulie84vert's Avatar
On my 84 Trans am I have no dash lights or radio. I haven't looked into to far yet but is there any wiring link between the two of them? All my other lights work, parking lights, taillights, light in the ash tray, foot well light, door chime etc all work.
Old Jan 18, 2016 | 12:21 AM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: No dash lights or radio
Start by checking the fuses first.
Old Jan 21, 2016 | 06:24 AM
Fuses where checked and are all good.
Old Jan 21, 2016 | 06:53 PM
Jaime-TA-84's Avatar
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
Does your shift indicator light also not work? (The light under the PRND21 panel). That one is on the same circuit as the Defogger control light, radio light, and heater-a/c control light, and the instrument panel lights. They all go through the INST FUSE (5A) to the dimming control by the headlight switch. The ashtray light is on a separate branch.
Do you hear the chime if you leave your lights on?
Old Jan 27, 2016 | 02:32 AM
The shift indicator lights are also out. I will check to see if the chime comes on if I leave the lights on. I do know the chime works when the door is open. I checked the 5a fuse and it was good. The car sat for a long time in a barn before I got it so I'm starting to think mice may have chewed on some wires.
Old Feb 3, 2016 | 07:03 PM
Franklindow's Avatar
Ok so I'm new to this and not real sure where to post... I have an 88 camaro and having problems with the dash lights. The rpm and speedo lights work but the temp gas and oil have lit up but are not now not sure what the issue is?
Old Feb 7, 2016 | 04:50 PM
OK so I figure out my lighting issue. It was tied in with the radio that was not functioning. All dash lights now work just have to find a radio to put in the car.
Old Dec 2, 2016 | 09:12 PM
230 firebird's Avatar
Car: 1987 pontiac firebird
Engine: sbc 350
Transmission: TKO 600 5 speed
Axle/Gears: 323 posi/disc from 86 gta
I am having a problem with my dash lights.None of my interior lights that come on when park light/headlight switch is activated.Also"headlight on "chime does not work.The 5a fuse for dash lights keeps blowing.I changed the chime relay and everything worked a few times and stopped.Now I am blowing the fuse again and chime doesn't sound
Old Dec 2, 2016 | 10:42 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
You should start your own thread. You need to inspect for a short in your wiring somewhere. Bare wire touching metal. Did you do any work in the vehicle right before this started? If so, that could lead you to the problem area.
Bubbajones_ya
May 22, 2016 10:02 PM
kanexpl
Jan 10, 2016 07:51 PM
Irockthedrag
Dec 31, 2015 08:36 PM
Eric-86sc
Dec 27, 2015 06:48 PM
jwstrand
Pacific Northwest Region
Dec 19, 2015 10:29 PM
