90-92 Speedometer Bench Testing - WIP
I had a post on FB trying to figure out this but was banned for posting a meme of michael jackson eating tide pods. Commie FB scum.
Anyways, I purchased a used speedometer off a kid online and when I put it in a while ago the speedometer stops climbing at 79mph. Suspecting the speedometer, since my original 110mph worked fine. I'm looking at a way to first benchtest the speedo, then figure out how to repair them properly since Hawks speedo guy is MIA.
Forewarning, it's been about 10 years since I messed with sine/square waves in a lab environment so feel free to add any information, may have forgotten something here or there.
Here's the outline of necessities to figure out:
1) Need source power (12-14v DC)
2) Need frequency generator (Square wave, not Sine)
3) Need oscilloscope to verify signal prior to going to speedo
4) Input Amplitude (volts) assuming anywhere from 0-5v max
5) Input Pulse Width
6) Input Cycle Time 0-145mph
I'll update this thread as I pioneer my way through this first using a spare 110mph cluster in case I blow something up LOL. Once that's figured out we'll have a way to diagnose the speedo
Working on a buy list for the equipment needed trying to keep it as economical as possible. So far, at $132 for all the equipment. Stuff should be in next week
Here are some of my notes so far, whether relevant or not to the cause
T5
Sensor on trans is an AC sine-wave generator
4 pulses per one sensor revolution
VSS Buffer Box
This sine-wave from the trans is sent to the VSS buffer box which converts it to a square-wave then sends to the cluster
90-92 Speedometer needs
4000 pulse per MILE input
SQUARE WAVE
1 Mile = 5,280 feet
10mph = 10.66fps
30mph = 44fps
50mph = 73.33fps
100mph = 146.667fps
T56
17 teeth on output shaft
17 VSS pulses PER drive shaft revolution
VSS output pulses per mile= 4000
SINE WAVE
VSS Buffer Box
SQUARE WAVE
1 Mile = 5,280 feet
10mph = 10.66fps
30mph = 44fps
50mph = 73.33fps
100mph = 146.667fps
T56
SINE WAVE
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 90-92 Speedometer Fix - WIP
Maybe this will help building a generator
http://lukeskaff.com/projects/car/gm...ace-scan-tool/
http://www.jbperf.com/JimStim/
I received the 12v adjustable psu, jumpers, oscope and freq generator.
Didn't realize I needed to build the freq generator that took me about 1-2hrs, but eventually got it to work kinda.
What's weird is both the wire for the tach and the speedo must be hooked up at the same time to both outputs on the freq generator or it doesnt work at all. Need to do some more investigation but depending on the range, it does make them both sweep from 0-MAX on both the tach and speedo, so success?
I need to buy a C1/C2 connector off someone so I can make an adequate test setup instead of 100 jumpers everywhere, will make a separate post to see if anyone wants to sell a set
Took this video at like 1am last night, so still more studying to do on this unit
Video:
https://photos.app.goo.gl/FZoF8taRBsu1M8CJ3
Video:
Would be curious to test the accuracy too
https://www.diyautotune.com/product/...tor-assembled/
I created a php script that when plugging in a few variables generates the expected frequency on the VSS and input to the cluster, not sure if anyone wants to check the math/logic, will update the thread as I continue testing/verification.
Ordered a different frequency generator and better oscope to better test the cluster. Still not sure why the freq generator only works when I have the square wave wire plugged into the speed prong and sine wave wire plugged into the tach prong.
If I remove the tach prong, the speedo stops working. Maybe a bad 2nd hand cluster? I'll attempt to verify with the better generator/oscope Friday and post the results
Note this is for a 1992 Camaro RS with 3.08 gears to test the 110mph speedo.
I ordered another pulse generator to see if I have any variation
TIRE INFORMATION
Tire Size: 245/50R16
Tire Diameter: 25.6456692913"
Tire Circumference - Free Hang: 80.56824615"
Tire Circumference - Rolling: 78.1511987655"
Tire Revolutions Per Mile - Free Hang: 786.414040614
Tire Revolutions Per Mile - Rolling: 762.821619396
DRIVETRAIN
Gear Ratio: 3.08
Output Shaft Teeth (reluctor ring): 9
Driveshaft Rotations Per Mile: 2422.15524509
Pulses Per Mile: 21799.3972058
EXPECTED FREQUENCY by MPH (from reluctor on trans)
1 MPH: 363.323286764 pulses per minute - 6.05538811273 pulses per second - 6.05538811273 Hz
2 MPH: 726.646573527 pulses per minute - 12.1107762255 pulses per second - 12.1107762255 Hz
3 MPH: 1089.96986029 pulses per minute - 18.1661643382 pulses per second - 18.1661643382 Hz
4 MPH: 1453.29314705 pulses per minute - 24.2215524509 pulses per second - 24.2215524509 Hz
5 MPH: 1816.61643382 pulses per minute - 30.2769405636 pulses per second - 30.2769405636 Hz
6 MPH: 2179.93972058 pulses per minute - 36.3323286764 pulses per second - 36.3323286764 Hz
7 MPH: 2543.26300735 pulses per minute - 42.3877167891 pulses per second - 42.3877167891 Hz
8 MPH: 2906.58629411 pulses per minute - 48.4431049018 pulses per second - 48.4431049018 Hz
9 MPH: 3269.90958087 pulses per minute - 54.4984930145 pulses per second - 54.4984930145 Hz
10 MPH: 3633.23286764 pulses per minute - 60.5538811273 pulses per second - 60.5538811273 Hz
11 MPH: 3996.5561544 pulses per minute - 66.60926924 pulses per second - 66.60926924 Hz
12 MPH: 4359.87944116 pulses per minute - 72.6646573527 pulses per second - 72.6646573527 Hz
13 MPH: 4723.20272793 pulses per minute - 78.7200454655 pulses per second - 78.7200454655 Hz
14 MPH: 5086.52601469 pulses per minute - 84.7754335782 pulses per second - 84.7754335782 Hz
15 MPH: 5449.84930145 pulses per minute - 90.8308216909 pulses per second - 90.8308216909 Hz
16 MPH: 5813.17258822 pulses per minute - 96.8862098036 pulses per second - 96.8862098036 Hz
17 MPH: 6176.49587498 pulses per minute - 102.941597916 pulses per second - 102.941597916 Hz
18 MPH: 6539.81916175 pulses per minute - 108.996986029 pulses per second - 108.996986029 Hz
19 MPH: 6903.14244851 pulses per minute - 115.052374142 pulses per second - 115.052374142 Hz
20 MPH: 7266.46573527 pulses per minute - 121.107762255 pulses per second - 121.107762255 Hz
21 MPH: 7629.78902204 pulses per minute - 127.163150367 pulses per second - 127.163150367 Hz
22 MPH: 7993.1123088 pulses per minute - 133.21853848 pulses per second - 133.21853848 Hz
23 MPH: 8356.43559556 pulses per minute - 139.273926593 pulses per second - 139.273926593 Hz
24 MPH: 8719.75888233 pulses per minute - 145.329314705 pulses per second - 145.329314705 Hz
25 MPH: 9083.08216909 pulses per minute - 151.384702818 pulses per second - 151.384702818 Hz
26 MPH: 9446.40545585 pulses per minute - 157.440090931 pulses per second - 157.440090931 Hz
27 MPH: 9809.72874262 pulses per minute - 163.495479044 pulses per second - 163.495479044 Hz
28 MPH: 10173.0520294 pulses per minute - 169.550867156 pulses per second - 169.550867156 Hz
29 MPH: 10536.3753161 pulses per minute - 175.606255269 pulses per second - 175.606255269 Hz
30 MPH: 10899.6986029 pulses per minute - 181.661643382 pulses per second - 181.661643382 Hz
31 MPH: 11263.0218897 pulses per minute - 187.717031495 pulses per second - 187.717031495 Hz
32 MPH: 11626.3451764 pulses per minute - 193.772419607 pulses per second - 193.772419607 Hz
33 MPH: 11989.6684632 pulses per minute - 199.82780772 pulses per second - 199.82780772 Hz
34 MPH: 12352.99175 pulses per minute - 205.883195833 pulses per second - 205.883195833 Hz
35 MPH: 12716.3150367 pulses per minute - 211.938583945 pulses per second - 211.938583945 Hz
36 MPH: 13079.6383235 pulses per minute - 217.993972058 pulses per second - 217.993972058 Hz
37 MPH: 13442.9616103 pulses per minute - 224.049360171 pulses per second - 224.049360171 Hz
38 MPH: 13806.284897 pulses per minute - 230.104748284 pulses per second - 230.104748284 Hz
39 MPH: 14169.6081838 pulses per minute - 236.160136396 pulses per second - 236.160136396 Hz
40 MPH: 14532.9314705 pulses per minute - 242.215524509 pulses per second - 242.215524509 Hz
41 MPH: 14896.2547573 pulses per minute - 248.270912622 pulses per second - 248.270912622 Hz
42 MPH: 15259.5780441 pulses per minute - 254.326300735 pulses per second - 254.326300735 Hz
43 MPH: 15622.9013308 pulses per minute - 260.381688847 pulses per second - 260.381688847 Hz
44 MPH: 15986.2246176 pulses per minute - 266.43707696 pulses per second - 266.43707696 Hz
45 MPH: 16349.5479044 pulses per minute - 272.492465073 pulses per second - 272.492465073 Hz
46 MPH: 16712.8711911 pulses per minute - 278.547853185 pulses per second - 278.547853185 Hz
47 MPH: 17076.1944779 pulses per minute - 284.603241298 pulses per second - 284.603241298 Hz
48 MPH: 17439.5177647 pulses per minute - 290.658629411 pulses per second - 290.658629411 Hz
49 MPH: 17802.8410514 pulses per minute - 296.714017524 pulses per second - 296.714017524 Hz
50 MPH: 18166.1643382 pulses per minute - 302.769405636 pulses per second - 302.769405636 Hz
51 MPH: 18529.4876249 pulses per minute - 308.824793749 pulses per second - 308.824793749 Hz
52 MPH: 18892.8109117 pulses per minute - 314.880181862 pulses per second - 314.880181862 Hz
53 MPH: 19256.1341985 pulses per minute - 320.935569975 pulses per second - 320.935569975 Hz
54 MPH: 19619.4574852 pulses per minute - 326.990958087 pulses per second - 326.990958087 Hz
55 MPH: 19982.780772 pulses per minute - 333.0463462 pulses per second - 333.0463462 Hz
56 MPH: 20346.1040588 pulses per minute - 339.101734313 pulses per second - 339.101734313 Hz
57 MPH: 20709.4273455 pulses per minute - 345.157122425 pulses per second - 345.157122425 Hz
58 MPH: 21072.7506323 pulses per minute - 351.212510538 pulses per second - 351.212510538 Hz
59 MPH: 21436.0739191 pulses per minute - 357.267898651 pulses per second - 357.267898651 Hz
60 MPH: 21799.3972058 pulses per minute - 363.323286764 pulses per second - 363.323286764 Hz
61 MPH: 22162.7204926 pulses per minute - 369.378674876 pulses per second - 369.378674876 Hz
62 MPH: 22526.0437793 pulses per minute - 375.434062989 pulses per second - 375.434062989 Hz
63 MPH: 22889.3670661 pulses per minute - 381.489451102 pulses per second - 381.489451102 Hz
64 MPH: 23252.6903529 pulses per minute - 387.544839215 pulses per second - 387.544839215 Hz
65 MPH: 23616.0136396 pulses per minute - 393.600227327 pulses per second - 393.600227327 Hz
66 MPH: 23979.3369264 pulses per minute - 399.65561544 pulses per second - 399.65561544 Hz
67 MPH: 24342.6602132 pulses per minute - 405.711003553 pulses per second - 405.711003553 Hz
68 MPH: 24705.9834999 pulses per minute - 411.766391665 pulses per second - 411.766391665 Hz
69 MPH: 25069.3067867 pulses per minute - 417.821779778 pulses per second - 417.821779778 Hz
70 MPH: 25432.6300735 pulses per minute - 423.877167891 pulses per second - 423.877167891 Hz
71 MPH: 25795.9533602 pulses per minute - 429.932556004 pulses per second - 429.932556004 Hz
72 MPH: 26159.276647 pulses per minute - 435.987944116 pulses per second - 435.987944116 Hz
73 MPH: 26522.5999337 pulses per minute - 442.043332229 pulses per second - 442.043332229 Hz
74 MPH: 26885.9232205 pulses per minute - 448.098720342 pulses per second - 448.098720342 Hz
75 MPH: 27249.2465073 pulses per minute - 454.154108455 pulses per second - 454.154108455 Hz
76 MPH: 27612.569794 pulses per minute - 460.209496567 pulses per second - 460.209496567 Hz
77 MPH: 27975.8930808 pulses per minute - 466.26488468 pulses per second - 466.26488468 Hz
78 MPH: 28339.2163676 pulses per minute - 472.320272793 pulses per second - 472.320272793 Hz
79 MPH: 28702.5396543 pulses per minute - 478.375660905 pulses per second - 478.375660905 Hz
80 MPH: 29065.8629411 pulses per minute - 484.431049018 pulses per second - 484.431049018 Hz
81 MPH: 29429.1862279 pulses per minute - 490.486437131 pulses per second - 490.486437131 Hz
82 MPH: 29792.5095146 pulses per minute - 496.541825244 pulses per second - 496.541825244 Hz
83 MPH: 30155.8328014 pulses per minute - 502.597213356 pulses per second - 502.597213356 Hz
84 MPH: 30519.1560881 pulses per minute - 508.652601469 pulses per second - 508.652601469 Hz
85 MPH: 30882.4793749 pulses per minute - 514.707989582 pulses per second - 514.707989582 Hz
86 MPH: 31245.8026617 pulses per minute - 520.763377695 pulses per second - 520.763377695 Hz
87 MPH: 31609.1259484 pulses per minute - 526.818765807 pulses per second - 526.818765807 Hz
88 MPH: 31972.4492352 pulses per minute - 532.87415392 pulses per second - 532.87415392 Hz
89 MPH: 32335.772522 pulses per minute - 538.929542033 pulses per second - 538.929542033 Hz
90 MPH: 32699.0958087 pulses per minute - 544.984930145 pulses per second - 544.984930145 Hz
91 MPH: 33062.4190955 pulses per minute - 551.040318258 pulses per second - 551.040318258 Hz
92 MPH: 33425.7423823 pulses per minute - 557.095706371 pulses per second - 557.095706371 Hz
93 MPH: 33789.065669 pulses per minute - 563.151094484 pulses per second - 563.151094484 Hz
94 MPH: 34152.3889558 pulses per minute - 569.206482596 pulses per second - 569.206482596 Hz
95 MPH: 34515.7122425 pulses per minute - 575.261870709 pulses per second - 575.261870709 Hz
96 MPH: 34879.0355293 pulses per minute - 581.317258822 pulses per second - 581.317258822 Hz
97 MPH: 35242.3588161 pulses per minute - 587.372646935 pulses per second - 587.372646935 Hz
98 MPH: 35605.6821028 pulses per minute - 593.428035047 pulses per second - 593.428035047 Hz
99 MPH: 35969.0053896 pulses per minute - 599.48342316 pulses per second - 599.48342316 Hz
100 MPH: 36332.3286764 pulses per minute - 605.538811273 pulses per second - 605.538811273 Hz
101 MPH: 36695.6519631 pulses per minute - 611.594199385 pulses per second - 611.594199385 Hz
102 MPH: 37058.9752499 pulses per minute - 617.649587498 pulses per second - 617.649587498 Hz
103 MPH: 37422.2985367 pulses per minute - 623.704975611 pulses per second - 623.704975611 Hz
104 MPH: 37785.6218234 pulses per minute - 629.760363724 pulses per second - 629.760363724 Hz
105 MPH: 38148.9451102 pulses per minute - 635.815751836 pulses per second - 635.815751836 Hz
106 MPH: 38512.2683969 pulses per minute - 641.871139949 pulses per second - 641.871139949 Hz
107 MPH: 38875.5916837 pulses per minute - 647.926528062 pulses per second - 647.926528062 Hz
108 MPH: 39238.9149705 pulses per minute - 653.981916175 pulses per second - 653.981916175 Hz
109 MPH: 39602.2382572 pulses per minute - 660.037304287 pulses per second - 660.037304287 Hz
110 MPH: 39965.561544 pulses per minute - 666.0926924 pulses per second - 666.0926924 Hz
DRIVETRAIN
Gear Ratio: 3.08
Here's the other part of the script, wouldn't fit, post was too long
EXPECTED FREQUENCY INPUT TO CLUSTER by MPH (4000 PPM)
MATH:
First I need to find how many hours it takes to travel each MPH rating
Hours = (1 / MPH)
Convert to minutes
Minutes = Hours * 60 ----------------------------------------------------------------------------------------
1 MPH: 66.6666666667 pulses per minute - 1.11111111111 pulses per second - 1.11111111111 Hz
2 MPH: 133.333333333 pulses per minute - 2.22222222222 pulses per second - 2.22222222222 Hz
3 MPH: 200 pulses per minute - 3.33333333333 pulses per second - 3.33333333333 Hz
4 MPH: 266.666666667 pulses per minute - 4.44444444444 pulses per second - 4.44444444444 Hz
5 MPH: 333.333333333 pulses per minute - 5.55555555556 pulses per second - 5.55555555556 Hz
6 MPH: 400 pulses per minute - 6.66666666667 pulses per second - 6.66666666667 Hz
7 MPH: 466.666666667 pulses per minute - 7.77777777778 pulses per second - 7.77777777778 Hz
8 MPH: 533.333333333 pulses per minute - 8.88888888889 pulses per second - 8.88888888889 Hz
9 MPH: 600 pulses per minute - 10 pulses per second - 10 Hz
10 MPH: 666.666666667 pulses per minute - 11.1111111111 pulses per second - 11.1111111111 Hz
11 MPH: 733.333333333 pulses per minute - 12.2222222222 pulses per second - 12.2222222222 Hz
12 MPH: 800 pulses per minute - 13.3333333333 pulses per second - 13.3333333333 Hz
13 MPH: 866.666666667 pulses per minute - 14.4444444444 pulses per second - 14.4444444444 Hz
14 MPH: 933.333333333 pulses per minute - 15.5555555556 pulses per second - 15.5555555556 Hz
15 MPH: 1000 pulses per minute - 16.6666666667 pulses per second - 16.6666666667 Hz
16 MPH: 1066.66666667 pulses per minute - 17.7777777778 pulses per second - 17.7777777778 Hz
17 MPH: 1133.33333333 pulses per minute - 18.8888888889 pulses per second - 18.8888888889 Hz
18 MPH: 1200 pulses per minute - 20 pulses per second - 20 Hz
19 MPH: 1266.66666667 pulses per minute - 21.1111111111 pulses per second - 21.1111111111 Hz
20 MPH: 1333.33333333 pulses per minute - 22.2222222222 pulses per second - 22.2222222222 Hz
21 MPH: 1400 pulses per minute - 23.3333333333 pulses per second - 23.3333333333 Hz
22 MPH: 1466.66666667 pulses per minute - 24.4444444444 pulses per second - 24.4444444444 Hz
23 MPH: 1533.33333333 pulses per minute - 25.5555555556 pulses per second - 25.5555555556 Hz
24 MPH: 1600 pulses per minute - 26.6666666667 pulses per second - 26.6666666667 Hz
25 MPH: 1666.66666667 pulses per minute - 27.7777777778 pulses per second - 27.7777777778 Hz
26 MPH: 1733.33333333 pulses per minute - 28.8888888889 pulses per second - 28.8888888889 Hz
27 MPH: 1800 pulses per minute - 30 pulses per second - 30 Hz
28 MPH: 1866.66666667 pulses per minute - 31.1111111111 pulses per second - 31.1111111111 Hz
29 MPH: 1933.33333333 pulses per minute - 32.2222222222 pulses per second - 32.2222222222 Hz
30 MPH: 2000 pulses per minute - 33.3333333333 pulses per second - 33.3333333333 Hz
31 MPH: 2066.66666667 pulses per minute - 34.4444444444 pulses per second - 34.4444444444 Hz
32 MPH: 2133.33333333 pulses per minute - 35.5555555556 pulses per second - 35.5555555556 Hz
33 MPH: 2200 pulses per minute - 36.6666666667 pulses per second - 36.6666666667 Hz
34 MPH: 2266.66666667 pulses per minute - 37.7777777778 pulses per second - 37.7777777778 Hz
35 MPH: 2333.33333333 pulses per minute - 38.8888888889 pulses per second - 38.8888888889 Hz
36 MPH: 2400 pulses per minute - 40 pulses per second - 40 Hz
37 MPH: 2466.66666667 pulses per minute - 41.1111111111 pulses per second - 41.1111111111 Hz
38 MPH: 2533.33333333 pulses per minute - 42.2222222222 pulses per second - 42.2222222222 Hz
39 MPH: 2600 pulses per minute - 43.3333333333 pulses per second - 43.3333333333 Hz
40 MPH: 2666.66666667 pulses per minute - 44.4444444444 pulses per second - 44.4444444444 Hz
41 MPH: 2733.33333333 pulses per minute - 45.5555555556 pulses per second - 45.5555555556 Hz
42 MPH: 2800 pulses per minute - 46.6666666667 pulses per second - 46.6666666667 Hz
43 MPH: 2866.66666667 pulses per minute - 47.7777777778 pulses per second - 47.7777777778 Hz
44 MPH: 2933.33333333 pulses per minute - 48.8888888889 pulses per second - 48.8888888889 Hz
45 MPH: 3000 pulses per minute - 50 pulses per second - 50 Hz
46 MPH: 3066.66666667 pulses per minute - 51.1111111111 pulses per second - 51.1111111111 Hz
47 MPH: 3133.33333333 pulses per minute - 52.2222222222 pulses per second - 52.2222222222 Hz
48 MPH: 3200 pulses per minute - 53.3333333333 pulses per second - 53.3333333333 Hz
49 MPH: 3266.66666667 pulses per minute - 54.4444444444 pulses per second - 54.4444444444 Hz
50 MPH: 3333.33333333 pulses per minute - 55.5555555556 pulses per second - 55.5555555556 Hz
51 MPH: 3400 pulses per minute - 56.6666666667 pulses per second - 56.6666666667 Hz
52 MPH: 3466.66666667 pulses per minute - 57.7777777778 pulses per second - 57.7777777778 Hz
53 MPH: 3533.33333333 pulses per minute - 58.8888888889 pulses per second - 58.8888888889 Hz
54 MPH: 3600 pulses per minute - 60 pulses per second - 60 Hz
55 MPH: 3666.66666667 pulses per minute - 61.1111111111 pulses per second - 61.1111111111 Hz
56 MPH: 3733.33333333 pulses per minute - 62.2222222222 pulses per second - 62.2222222222 Hz
57 MPH: 3800 pulses per minute - 63.3333333333 pulses per second - 63.3333333333 Hz
58 MPH: 3866.66666667 pulses per minute - 64.4444444444 pulses per second - 64.4444444444 Hz
59 MPH: 3933.33333333 pulses per minute - 65.5555555556 pulses per second - 65.5555555556 Hz
60 MPH: 4000 pulses per minute - 66.6666666667 pulses per second - 66.6666666667 Hz
61 MPH: 4066.66666667 pulses per minute - 67.7777777778 pulses per second - 67.7777777778 Hz
62 MPH: 4133.33333333 pulses per minute - 68.8888888889 pulses per second - 68.8888888889 Hz
63 MPH: 4200 pulses per minute - 70 pulses per second - 70 Hz
64 MPH: 4266.66666667 pulses per minute - 71.1111111111 pulses per second - 71.1111111111 Hz
65 MPH: 4333.33333333 pulses per minute - 72.2222222222 pulses per second - 72.2222222222 Hz
66 MPH: 4400 pulses per minute - 73.3333333333 pulses per second - 73.3333333333 Hz
67 MPH: 4466.66666667 pulses per minute - 74.4444444444 pulses per second - 74.4444444444 Hz
68 MPH: 4533.33333333 pulses per minute - 75.5555555556 pulses per second - 75.5555555556 Hz
69 MPH: 4600 pulses per minute - 76.6666666667 pulses per second - 76.6666666667 Hz
70 MPH: 4666.66666667 pulses per minute - 77.7777777778 pulses per second - 77.7777777778 Hz
71 MPH: 4733.33333333 pulses per minute - 78.8888888889 pulses per second - 78.8888888889 Hz
72 MPH: 4800 pulses per minute - 80 pulses per second - 80 Hz
73 MPH: 4866.66666667 pulses per minute - 81.1111111111 pulses per second - 81.1111111111 Hz
74 MPH: 4933.33333333 pulses per minute - 82.2222222222 pulses per second - 82.2222222222 Hz
75 MPH: 5000 pulses per minute - 83.3333333333 pulses per second - 83.3333333333 Hz
76 MPH: 5066.66666667 pulses per minute - 84.4444444444 pulses per second - 84.4444444444 Hz
77 MPH: 5133.33333333 pulses per minute - 85.5555555556 pulses per second - 85.5555555556 Hz
78 MPH: 5200 pulses per minute - 86.6666666667 pulses per second - 86.6666666667 Hz
79 MPH: 5266.66666667 pulses per minute - 87.7777777778 pulses per second - 87.7777777778 Hz
80 MPH: 5333.33333333 pulses per minute - 88.8888888889 pulses per second - 88.8888888889 Hz
81 MPH: 5400 pulses per minute - 90 pulses per second - 90 Hz
82 MPH: 5466.66666667 pulses per minute - 91.1111111111 pulses per second - 91.1111111111 Hz
83 MPH: 5533.33333333 pulses per minute - 92.2222222222 pulses per second - 92.2222222222 Hz
84 MPH: 5600 pulses per minute - 93.3333333333 pulses per second - 93.3333333333 Hz
85 MPH: 5666.66666667 pulses per minute - 94.4444444444 pulses per second - 94.4444444444 Hz
86 MPH: 5733.33333333 pulses per minute - 95.5555555556 pulses per second - 95.5555555556 Hz
87 MPH: 5800 pulses per minute - 96.6666666667 pulses per second - 96.6666666667 Hz
88 MPH: 5866.66666667 pulses per minute - 97.7777777778 pulses per second - 97.7777777778 Hz
89 MPH: 5933.33333333 pulses per minute - 98.8888888889 pulses per second - 98.8888888889 Hz
90 MPH: 6000 pulses per minute - 100 pulses per second - 100 Hz
91 MPH: 6066.66666667 pulses per minute - 101.111111111 pulses per second - 101.111111111 Hz
92 MPH: 6133.33333333 pulses per minute - 102.222222222 pulses per second - 102.222222222 Hz
93 MPH: 6200 pulses per minute - 103.333333333 pulses per second - 103.333333333 Hz
94 MPH: 6266.66666667 pulses per minute - 104.444444444 pulses per second - 104.444444444 Hz
95 MPH: 6333.33333333 pulses per minute - 105.555555556 pulses per second - 105.555555556 Hz
96 MPH: 6400 pulses per minute - 106.666666667 pulses per second - 106.666666667 Hz
97 MPH: 6466.66666667 pulses per minute - 107.777777778 pulses per second - 107.777777778 Hz
98 MPH: 6533.33333333 pulses per minute - 108.888888889 pulses per second - 108.888888889 Hz
99 MPH: 6600 pulses per minute - 110 pulses per second - 110 Hz
100 MPH: 6666.66666667 pulses per minute - 111.111111111 pulses per second - 111.111111111 Hz
101 MPH: 6733.33333333 pulses per minute - 112.222222222 pulses per second - 112.222222222 Hz
102 MPH: 6800 pulses per minute - 113.333333333 pulses per second - 113.333333333 Hz
103 MPH: 6866.66666667 pulses per minute - 114.444444444 pulses per second - 114.444444444 Hz
104 MPH: 6933.33333333 pulses per minute - 115.555555556 pulses per second - 115.555555556 Hz
105 MPH: 7000 pulses per minute - 116.666666667 pulses per second - 116.666666667 Hz
106 MPH: 7066.66666667 pulses per minute - 117.777777778 pulses per second - 117.777777778 Hz
107 MPH: 7133.33333333 pulses per minute - 118.888888889 pulses per second - 118.888888889 Hz
108 MPH: 7200 pulses per minute - 120 pulses per second - 120 Hz
109 MPH: 7266.66666667 pulses per minute - 121.111111111 pulses per second - 121.111111111 Hz
110 MPH: 7333.33333333 pulses per minute - 122.222222222 pulses per second - 122.222222222 Hz
MATH:
Hours = (1 / MPH)
Convert to minutes
I'm a little confused as to if my calculations on the 4000ppm are incorrect, or if the speedometer itself is just old and not very accurate anymore.
Received the new OScope and Signal generator, and although were much more expensive, they work flawlessly for testing.
Just a note, here's a video for testing the speedo operation. The odometer is driven via a small 4 wire motor that's actuated via the chip under the speedo. The chip takes in the 4000PPM signal and converts to something the motor uses to turn the needle.
