Possibly vats ?
Old Jan 21, 2019 | 02:14 PM
Luis_90iroc's Avatar
Possibly vats ?
So i have a 1990 camaro, i swapped my steering column for a 92 steering column cause with mine the steering knuckle broke. Everything went along smoothly ,easy replacement but 1 plug was different from mine. It was missing some wires in the connector so something wasnt gonna work. When i go to crank it , nothing happens .some dash lights turn on and the temp.needle goes out of wack. Could that plug missing some wires be my problem ? I bought a new ignition for it with the key my car is supposed to have ,key#5. So right now im stuck and was wondering if anyone could help or had the same problem amd could guide me in the right direction
Old Jan 21, 2019 | 06:19 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Possibly vats ?
When you turn thw key does the security come on and stay on? When you had a new key made with the chip did you have your old one tested to make sure the new key was made with the correct chip?
Old Jan 21, 2019 | 06:32 PM
Re: Possibly vats ?
the car is not with me so i cannot check right now but when i got the key , they had an original key , they tested mine amd from there they sold me an original key with the same resistance as my original key
Old Jan 21, 2019 | 06:33 PM
Re: Possibly vats ?
Im not 100% positive but when i had the key in the ignition i think the security light did stay on
Old Jan 21, 2019 | 09:06 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Possibly vats ?
Did the new ignition tumbler have an orange wire on it with a plug?
Old Jan 21, 2019 | 09:29 PM
Re: Possibly vats ?
yes ,plugged it in. Correct me if im wrong but that's for the vats right?
Old Jan 21, 2019 | 09:52 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Possibly vats ?
Yeah it is. Confirm if the security light is on. If its not it might just be an adjustment of the ignition switch on the column that the tumbler pushes with the metal rod. This will also cause no start if its not adjusted correctly.
Old Jan 27, 2019 | 02:19 PM
Re: Possibly vats ?
so the security light turns on but i don't hear the fuel pump turning on. Im going to mess with the rod and get it to turn with the key
Old Jan 27, 2019 | 02:24 PM
Re: Possibly vats ?
So there are 2 rods , theres one that is turning with the key and the other that isnt .the one that isnt turning is is touching something that resembles a button.is that how its supposed to be ?
Old Jan 27, 2019 | 03:01 PM
Re: Possibly vats ?
Is it possible where the rod goes on this isnt in the right spot ?
Old Jan 27, 2019 | 03:03 PM
Re: Possibly vats ?
Also on the starter im not getting power to the smaller wire, i gave power to that smaller wire on the starter and it spun. What is my issue there ?
Old Jan 27, 2019 | 07:09 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Possibly vats ?
Lets start with the basics.
Your security light comes on with the ignition. Does is stay on or turn off with the ignition on?
Old Jan 27, 2019 | 08:07 PM
Re: Possibly vats ?
it stays on
Old Jan 27, 2019 | 09:42 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Possibly vats ?
Ok so you do have a vats problem.
forget about anything except vats.
Double check your vats connector and double check your keys.
Old Jan 27, 2019 | 09:51 PM
Re: Possibly vats ?
What is the security light supposed to do when there is no problem? And does that also explain why the fuel pump isnt turning on with the key in the on position ?
Old Jan 27, 2019 | 10:32 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Possibly vats ?
It comes on for 2 seconds then shuts off. If it stays on then VATS is enabled and cuts power to the fuel pump and doesnt energize starter enable relay.
Old Jan 27, 2019 | 10:34 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Possibly vats ?
I would start with the key then work downward.
next would be the ignition tumbler.
do you still have your old ignition?
Old Jan 27, 2019 | 11:55 PM
Re: Possibly vats ?
No i do not , would it be easier just bypassing the vats ?
Old Jan 28, 2019 | 06:19 AM
Re: Possibly vats ?
Or could i pay the money and get the key programmed ?
Old Jan 28, 2019 | 11:07 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Possibly vats ?
Only way to truly bypass is to have a new chip made with vats disabled and the starter enable relay.
Old Jan 28, 2019 | 11:08 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Possibly vats ?
Didnt you already have the key made with the chip?
Old Jan 28, 2019 | 11:34 AM
Re: Possibly vats ?
they a had a blank key with the resistor pellet in the key. I wemt there and they also cut the key.
Old Jan 28, 2019 | 12:57 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Possibly vats ?
Since you dont have the original tumbler what I would do is check the old key and new key and make sure they are the same. If they are then make sure the wires coming from the new tumbler are ok and not broken. (Unplug the wire from under the dash and with the new key in the ignition check for continuity) this will tell you if your wires and key are all intact and operating
PeterFeix
May 29, 2015 09:49 PM
89 ROCKINGFLAME
Jul 28, 2011 08:03 PM
theNMBR27
Jul 6, 2010 01:07 AM
89 4Mula 350 Tbi
Dec 28, 2001 10:25 AM
camaroguy99
Jul 8, 2001 11:47 PM
