1989 firebird electric fan not working
Old Feb 19, 2019 | 09:42 PM
BarryKohl's Avatar
fan won't kick on when engine overheats.
when you turn on the a/c the fan kicks on.
had someone look at it and said the ecm is the issue.
replaced the ecm and no change.
checked thermostat and is ok.
I guess I could test the wiring from the thermstat to the ecm and see if there is current.
any ideas?
Old Feb 19, 2019 | 09:47 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1989 firebird electric fan not working
What engine ? V6 2.8l or v8 tpi or tbi ?
The thermostat doesn’t control the fan, either it’s ecm controls the relay or there is a cylinder head temp switch.
Old Feb 20, 2019 | 09:52 AM
BarryKohl's Avatar
thx i will try the relay.
Old Feb 20, 2019 | 12:24 PM
Engine: Lb9
Transmission: M20
what are you working on ?
two fan setup ?
Old Feb 20, 2019 | 09:32 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
The fact that AC turns on the fan shows the relay to be working fine. Depending on the engine and fan setup it sounds like a common failed fan switch. Tell us which engine
and whether you have single or dual fans
Old Feb 21, 2019 | 09:33 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
There are two "temp sensors" on the car, one drives the fans and one drives the gauge. If you take the wire off the fan switch and touch it to ground with the key on the fan should start up. If it does the switch is bad, if it doesn't then you have a wiring issue or relay issue.
Old Feb 21, 2019 | 11:30 AM
Engine: Lb9
Transmission: M20
I think the op has left. Depending on the application there is the ecm controls switch the cts.
Like you mention a cylinder head temp switch that’s normally open circuit.
To the op if you want help diagnosing the issue instead of throwing parts at the problem. You need to state what your working on. Your signature is incomplete.
Old Feb 21, 2019 | 12:16 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
This might not be the issue but just a tip for those who are experiencing the same problems. Happened to me once were my fan wouldn't turn on. The issue was that the contacts on the fan plug were so bent that they weren't making contact. Just took a small flathead and opened up the contacts and problem fixed.
Metallicelmo
Nov 26, 2008 04:28 AM
bizmark13
Sep 13, 2006 05:55 AM
golden
Apr 7, 2006 08:53 PM
92 305 BIRD
May 30, 2003 12:00 AM
