Alternator Wiring Help Please!!
Old Feb 21, 2019 | 10:10 PM
jaystoy's Avatar
I do not know why only the pictures came up and all my writing disappeared, ugh. So my 1987 Camaro. My son and I pulled the 2.8 .we marked every wire. We have pulled the ecm and any wires not needed .We dropped in a 350. We tossed the alternator that was on the car, and I figured we could use this 100 amp powerwashed I had on the shelf .But ofcourse, the wires are different. So I ran the black/red strike wire from the dist block behind headlights to the back of alternator as was on the v6 .I assume the red wire to the new 2 wire plug will connect to the red that was fusible and went down to the starter .I believe the new white wire connects to the brown wire for garage? I don't know what to do with the tan/white wire?? Do I need it? If so, can I splice it right into the brown wire attached to white?? I no longer and running the electric fan through the original relay nor am I running electric fuel pump. So what's the deal with that wire?? Thanks
Old Feb 21, 2019 | 10:13 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Alternator Wiring Help Please!!
Are you going from cs to si ?
Old Feb 21, 2019 | 10:19 PM
Engine: Lb9
Transmission: M20
Old Feb 22, 2019 | 08:01 AM
jaystoy's Avatar
that Sir, begs my ignorance. I am not sure
Old Feb 22, 2019 | 11:02 AM
Engine: Lb9
Transmission: M20
Looks like post 1 goes to your ignition switch. Switched power
post 2 goes to the batter post of the alternator.
the power wire to the starter on the battery lug post of the alternator.
and disregard the brown wire for the idiot light.
Old Feb 22, 2019 | 11:07 AM
Engine: Lb9
Transmission: M20
To get a check engine light , if I’m reading this correctly the brown goes to post 1
Old Feb 22, 2019 | 02:42 PM
jaystoy's Avatar
Hmm.....so run red power wire from alternator....to the...alternator?? OK
Old Feb 23, 2019 | 12:13 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Here Ya' Go,..........
https://www.ebay.com/itm/Alternator-Conversion-Lead-Delco-10SI-12SI-15SI-to-CS130-CS144-with-resistor/190717117047?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D55991%26meid%3D88f7c37dacc6485489a0859e1c5e7b2c%26pid%3D100008%26rk%3D2%26rkt%3D5%26mehot%3Dag%26sd%3D162516936440%26itm%3D190717117047&_trksid=p2047675.c100008.m2219
Old Feb 23, 2019 | 02:43 PM
jaystoy's Avatar
Nice!!!!
Old Feb 23, 2019 | 08:01 PM
jaystoy's Avatar
I see on ebay two kinds......the one you posted that come with resistor and there are other without resistor. Don't know which I need
Jay
Old Feb 24, 2019 | 07:02 AM
jaystoy's Avatar
My 87 may have a warning light I assume....don't remember, but I do have the factory volt gauge which I want to work...so with resistor or w/o?
scagz2.8l
Carburetors
Aug 11, 2014 10:21 AM
porschev8
Aug 27, 2006 07:44 AM
ChevyGuy87
May 11, 2006 09:24 PM
89ROC
Feb 3, 2003 09:43 AM
bad@ss89camaro
Jun 4, 2001 09:38 PM
