Performance Sound Buzzing?
Old Mar 7, 2019 | 07:58 PM
kenbob's Avatar
Car: 86 trans-am 1LE G92 WS.6
Engine: 305 LB9
Axle/Gears: 2.77 soon to have 3.45
Hey guys I know this is an old thread but I finally found some subs that work and all I get is a buzzing can someone please tell me what can cause this issue I'm great with everything except stereos
Old Mar 8, 2019 | 09:26 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Performance Sound Buzzing?
I moved this to electronics, these guys are smarter about stereo issues than the history board. I hope someone in here can help him
Old Mar 8, 2019 | 10:08 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
What is your current sound setup? Stock head unit? Stock speakers?
Old Mar 8, 2019 | 10:09 AM
kenbob's Avatar
Engine: 305 LB9
Thanks I appreciate it
Old Mar 8, 2019 | 10:20 AM
kenbob's Avatar
Engine: 305 LB9
Aftermarket head unit aftermarket speakers in stock location my 4x6's are from kicker they're the CS series and sound grea.t I have a 5 1/4 inch subwoofers they don't make any sound until the gain switch is pushed and when it's pushed they make this click, pop, and loud buzzing. I'm trying to figure it out by myself so I don't have to pay someone to fix it
Old Mar 8, 2019 | 12:23 PM
Engine: 350 TPI L98
Transmission: WC T5
Ok. Are these powered subs (have their own internal amplifier) or do you an aftermarket amp? Sub, make and model would help.
Old Mar 8, 2019 | 12:49 PM
kenbob's Avatar
Engine: 305 LB9
Everything but the deck & speakers is factory
Old Mar 8, 2019 | 01:00 PM
kenbob's Avatar
Engine: 305 LB9
Factory amplifier with aftermarket stock size speakers
Old Mar 8, 2019 | 03:01 PM
okfoz's Avatar
I think There is your problem. The Stock amp is designed for 10 ohm speakers, 99% of all aftermarket auto speakers are 4 ohm, They pop because you are over driving the amp and it is clipping the sound.. If you turn up the gain about 1/2 way it will sound fine. Ideally you should run 2 4 ohm speakers or get some 6 ohm resistors to add to the resistance to eliminate the pop. Sure it will not be as loud BUT it will not blow your amp, or your speakers...
Some of the car stereo guys here are smarter than me and will hopefully correct me where I went wrong.
John
Old Mar 8, 2019 | 05:52 PM
kenbob's Avatar
Engine: 305 LB9
Hey John, you were dead on the money I put an inline 6 ohm resistor and BAM! My subs kicked on and sound great not full potential but the work just fine for me thanks guys
Old Mar 9, 2019 | 09:24 AM
Engine: 350 TPI L98
Transmission: WC T5
Glad you got it sorted out kenbob! Come to some of meets on our regional boards!
Old Mar 9, 2019 | 12:23 PM
kenbob's Avatar
Engine: 305 LB9
I just sourced a new 3 series 9 bolt diff I currently have a 2 series 2.77 and I just did a 5 speed swap. Those gears don't work too well with a WC t5 so I ordered a new set of 3.70 and got my speedometer gears set for the 3.70's when I did the swap so around mid March I should be traveling with one bad *ss WS6 with 4 disk brakes performance suspension and thanks to y'all performance sound.
maroe624
Mar 9, 2019 04:47 PM
Tuned Performance
Mar 8, 2019 09:29 PM
Jorlain
Mar 6, 2019 08:06 PM
ChevyK10
Mar 5, 2019 08:16 PM
88ricekiller
Mar 1, 2019 09:30 AM
