Fan no run
Old Apr 7, 2019 | 08:04 AM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Fan no run
Dual cooling fans. The AC compressor don't kick in when I turn the AC on. Neither does the passenger side or driver's side.
Old Apr 12, 2019 | 03:55 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Fan no run
Not trying to be smart-***, but is this the same song second verse of the wiring harness
issues in other threads?
I'm tellin you dude, Service Manual w/ total electrical system info will be money well spent.
Old Apr 12, 2019 | 05:03 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Re: Fan no run
I have a GM Service Manual, What's your Engine VIN?
Old Apr 12, 2019 | 05:08 PM
Engine: 305 / 350
Re: Fan no run
This is has dual fans...
Old Apr 12, 2019 | 09:01 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: Fan no run
the fans are in a 89 formula 5.7 car. The mess of a wiring problem are in a 88 Camaro with 5.0tbi. I would love to get a service manual for all 84 to 90 Camaro and firebird. Even one would be great. I have no credit cards but Lowes and don't know how safe debit card is. Or if I can buy with that.
Old Apr 12, 2019 | 09:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fan no run
Not sure if these are still valid
https://www.thirdgen.org/forums/tech...ce-manual.html
https://www.thirdgen.org/forums/tech...ro-repair.html
Engine: 305 / 350
Re: Fan no run
the fans are in a 89 formula 5.7 car..
You scrolled right past the helpful information, that I offered out of my GMSM without acknowledgement. And yes I am being a Smart-A$$ because I tried to save you time and a buck... I chose that diagram because VIN code 8 is much better known as the L98 5.7 V8 TPI, standard in the 1985-91 Corvette and optional in the 1987-92 Camaro/Firebird platform which if I'm not mistaken is what your asking for help with.
Hope it helps...
Old Apr 12, 2019 | 09:15 PM
Engine: Lb9
Transmission: M20
Re: Fan no run
Here is the primary fan for 89 tpi
Old Apr 12, 2019 | 10:52 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: Fan no run
According to these diagrams, there can only be a few problems. sensor, wire, fan motor, relay, ecm
iroc192
Dec 16, 2007 07:43 PM
aziroc
Jul 19, 2002 02:44 PM
fiream
Jul 19, 2001 08:52 AM
