Universal Power Antenna Wiring Question
Old May 19, 2019 | 11:32 AM
87irocjhawk's Avatar
Car: 1987 Iroc-Z
Engine: 5.7
I have a Metra power antenna mounted to replace one that was bent and stuck up on my 1987 Iroc-Z, but having some trouble wiring it in. The existing harness was wired grey, green, and white, but the new antenna came with red (unswitched power), blue (switched power) and black ground. Is there a way to splice the red and blue wires into the existing wiring harness for the relay? Thanks for the help.
Old May 19, 2019 | 01:30 PM
GeneralDisorder's Avatar
Re: Universal Power Antenna Wiring Question
Jeezuz. Don't install that garbage - get the proper direct fit antenna.
Amazon Amazon
GD
Old May 19, 2019 | 03:50 PM
Car: 1987 Iroc-Z
Engine: 5.7
I was about to give you s**t for your unhelpful response, but then I saw the Amazon link. I've been looking for that for weeks and keep finding the same one as I have, or one that looks exactly the same. They say direct fit but in the small print say they may need some modification - which is adding about 6 inches to the mast and they're wired completely different
Ordered the crown one - should make install a lot easier.
Old May 19, 2019 | 03:58 PM
Unfortunately Crown seems to have forgot that this fits F body's. They sell it for Jeeps and don't list that it fits our cars. I have one in my Trans Am. Works like factory and same wiring.
GD
Old May 19, 2019 | 07:46 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
It even has the correct grommet...good find.
Old May 24, 2019 | 03:04 PM
Car: 1987 Iroc-Z
Engine: 5.7
I installed the Crown antenna this week. The quality seems good and it clipped right in to the relay and even included the rubber grommet. It sticks a little and needs help going up and down some times, but it's in and I can drive it now.
Old May 24, 2019 | 05:40 PM
Huh. Mine doesn't stick at all. Maybe try lubing it with some lithium grease. Also check that you are getting good power to it. I can imagine a voltage drop might hurt it's performance.
GD
Old May 25, 2019 | 02:54 PM
pognoot's Avatar
Question. So my GTA has a "garbage" aftermarket power antenna that was installed last year, and it's already crapped out! Jeebus. As part of the install, the relay was removed and it has the red/blue/black wire configuration going to the unit. I tested the power on the On/Off blue lead, and it's good. So....once an aftermarket antenna has been installed, and the relay removed, would it be a massive undertaking to replace it with the Crown? Or, since my car is already down the road of cheap-aftermarket, should I just accept what I have and replace with another aftermarket....?
Old May 25, 2019 | 05:42 PM
Definitely put the wiring back to stock and put the factory style antenna back in. That's what I did on my 86 TA. Mine also had a failed aftermarket in there. My relay was intact they just stole switched power from the interior dome lighting. I wired it back to the relay and I did have to splice the coax antenna line to get that back to stock. Someday I might swap in a stock coax from my parts car. The way I have mine setup though, I lopped off the harness for the antenna and put in a weatherpack connector on the outside of the fender wall right next to the antenna. So now if I need to change the antenna, I just pull down the fender liner, unplug it and unbolt the coax from the mast and plug in the new one (after crimping on a matching weatherpack). No interior panels removed or fishing wire or messing with the grommet.
GD
Old Jul 22, 2019 | 06:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Any short term feedback on the amazon piece?
Old Aug 5, 2019 | 09:25 PM
Car: 1987 Iroc-Z
Engine: 5.7
The Crown antenna from Amazon lasted about 2 weeks before crapping out on a road trip when it got stuck halfway down - or halfway up. It sounds like it slipped the gear so at some point I'll pull it again and try to rebuild it. Until then it's disconnected and in the down position.
Old Aug 5, 2019 | 09:48 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Damn, I gonna order one, but keep my OE for parts. Ive already fixed it once (cable) and its dead again.I think its the motor this time.
Old Aug 10, 2019 | 01:46 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
It does look good. Plugged it in to see if its DOA. Still need to install it though...we will see. Of course when i reconnected my original one, it worked again. Then right after stopped working....again, then again started working. So its not completely dead yet! I got mine on ebay FWIW. Only difference is, cable needs to be on the arrow side, but the tube is easy to rotate 180 degrees.
Old Aug 10, 2019 | 03:08 PM
Mine is still working just fine. Been well over a year. I daily drive too so it's up and down a dozen times a day.
GD
Old Aug 10, 2019 | 04:52 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Hope my luck is as good as yours.
2012sergen11
Car Audio
Jul 21, 2016 10:08 PM
Ellis87z28
Car Audio
Feb 13, 2015 08:06 PM
Jimmmer
May 21, 2012 07:37 AM
PAformula
Mar 22, 2007 06:53 PM
alivenkickin29
Feb 2, 2006 01:38 AM
