Installing Holley Sniper, have questions
Hi,
I am in the process of installing the Holley Sniper EFI system in my 87 Firebird 305 engine, which was carb.
I believe there are some on this site that have done this. My questions are: Will I loose speedometer?, I believe I will loose tach,
Is there any other losses that I should be aware of? How do I resolve these issues.
Thanks,
Louis
Thanks,
Louis
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Installing Holley Sniper, have questions
Is your speedometer cable drive ?
The tach can be hooked to the negative side of the ignition coil.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
The tach is part of the engine harness, but connected to the coil, so you just need to retain that from the engine harness. I'd have to look in my factory manual, but the VSS comes from the trans and should either go directly to the dash, or a buffer box? That should be easy to retain also. You can also use the coil wire as the ignition source for the Holley harness, that is how I wired in my Holley EFI in my other vehicles.
I would start by reading the LS swap guide for the body side stuff, it will apply to any engine swap that isn't factory.
Thanks,
Louis
Engine: Lb9
Transmission: M20
The tach wires run through c100 it’s a white wire going to the coil. If you don’t have a cable drive Vss retain the wiring from the Vss to the Vss buffer. It’s all connected through the passengers side body pass through connector.
The heavy red wire in the gray connector is the 12 volt I am using for the Sniper efi. Can you clear this up for me.
Thanks,
louis
Engine: Lb9
Transmission: M20
Your correct on the white wire.
Great, one last question, I assume this wire will attach to the "tach" terminal of the HEI distributor that I am using. The install of the sniper has one wire already attached to the "tach" terminal, one yellow one labeled
"coil". Do I piggy back both wires?
And thanks for your help, really appreciate it.
Louis
Louis
Engine: Lb9
Transmission: M20
Do you have a schematic showing the yellow wire or does it say coil negative?
Car: 92 Firebird
Engine: 4.8 LR4
Louis
Louis
AGAIN reference what YOU GOT with your kit, but this shows page 6 that the yellow wire is for the tach input to the Holley system
https://documents.holley.com/199r11193.pdf
If this is what you actually have, then you could either use the coil negative for your tach, OR the brown wire from the Holley to drive your tach.
You should really be referencing the instructions or the wire schematic from the Holley setup instead of asking us.
Thanks,
Louis
Engine: Lb9
Transmission: M20
I know this is a old thread . Just curious what distributor did you end up using ?
Louis
Engine: Lb9
Transmission: M20
Over all do you like the sniper, I’m debating on this system or just tbi. It’s for a old 76 Chevy truck.
All in all, I am very happy with the unit. I see more power, a little better gas mileage and fast starts. You can just install it with the recommended settings and forget about it or if you are inclined, go crazy with tunning via laptop.
Louis
Engine: Lb9
Transmission: M20
Thanks for the feedback, I can’t leave well enough alone. I would tinker with it lol.
http://www.EFISystemPro.Com
unseenT/A
Aug 30, 2017 07:21 AM
88tpi350
Jul 13, 2009 03:25 PM
