fusible links
Old Aug 5, 2019 | 01:13 PM
harmoe's Avatar
fusible links
I am trying to locate all the fusible links on my 1992 firebird 5.0 l I have located the 2 at the starter I am looking for the link for the headlight switch and the one for the alternator and i belive ther is one or 2 for the headlamp motors.
Old Aug 5, 2019 | 02:29 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: fusible links
There are no fusible links for the headlights or alternator, at least not according to the factory manuals
Old Aug 5, 2019 | 02:42 PM
harmoe's Avatar
Re: fusible links
I tested the links at the starter got 12 + volts they seem to be good.
I had had the car running went turn the headlights on. Everything died no power any where
don't know where to turn
Old Aug 5, 2019 | 03:32 PM
vorteciroc's Avatar
Top Answer: 1
Re: fusible links
Check that the main ground connection from the battery to the engine is not broken or corroded.
Old Aug 5, 2019 | 03:43 PM
harmoe's Avatar
Re: fusible links
I will check the ground tomorrow. The car has been restored 2 years ago
the Haynes manual shows links on the switch The alternator and the light motors I want locate and test them
Old Aug 5, 2019 | 04:01 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Re: fusible links
OK, I was wrong somewhat wrong on the headlight circuit. There is a fusible link for the hot feed circuit, but it also feeds other devices on the circuit, it isn't dedicated to the headlights. That is at the starter and feeds into cavity G5 in the C100 bulkhead. I was wrong about the alternator, that shows the link is at the end that is connected to the starter solenoid connection where the other hot feeds are
There is a circuit breaker inside the headlight switch, it may be the switch has failed.
Old Aug 6, 2019 | 06:59 AM
vorteciroc's Avatar
Top Answer: 1
Re: fusible links
Nothing should shut off power to everything else except if 12+ can not return to ground with enough current...
I see this when smaller ground connections are returning 12+ (when there is a low current draw)
However usually the main ground or a large ground strap is disrupted (high current draw can not pass through the resistance of the smaller grounds).
Old Aug 6, 2019 | 09:07 AM
harmoe's Avatar
Re: fusible links
pink wires have the fusible links
I have found a terminal block next to the radiator there are 5 connections to the post one goes to the fan one is the positive from the battery what are the remaining 3 . 2 of them have fusible links.
Old Aug 6, 2019 | 02:40 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: fusible links
I don't think that is factory, but I could be wrong...
Old Aug 6, 2019 | 05:39 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: fusible links
Start at the battery, make sure terminals are clean and tightened down. Make sure battery is @ 12+ volts (12.4~12.8)
Check battery cable at the starter. Check ground on block. Those are the primary leads of power to everything in the car. .
rbltoy
Oct 31, 2001 02:41 AM
I ROCK
Apr 21, 2001 03:22 PM
jayman350
Mar 22, 2001 09:46 PM
Josh 91RS
Feb 21, 2001 01:12 AM
