Power window question
Old Mar 11, 2020 | 10:12 AM
MicksIroc's Avatar
I dont have a main harness in my car and i have my door panels off. I would like to test my power windows by splicing a 12 volt supply. Light blue and tan/blue stripe wires. Which one is positive up and then positive down or vice a versa?
Old Mar 11, 2020 | 10:40 AM
Drew's Avatar
Re: Power window question
Two pins on the motor. Positive to one, negative to the other, it'll turn one way or the other. If it's not going the direction you want, reverse your connections (polarity) and it'll go the other way. 50/50 chance you'll get it right the first try. If you get it wrong it's no different than bumping the window switch when the window is already all the way up or all the way down.
Old Mar 12, 2020 | 09:36 AM
MicksIroc's Avatar
Im thinking they are both positive? with a common ground at the switch.
Old Mar 12, 2020 | 01:23 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Old Mar 12, 2020 | 01:26 PM
Drew's Avatar
Dear horse,
There is the water.
Cordially,
Drew
Old Mar 12, 2020 | 03:01 PM
MicksIroc's Avatar
Thank you Drew/John worked great both windows work well. The drivers side unfortunately broke the "white plastic top stop guide" uggh and its riveted into the glass.
Old Mar 12, 2020 | 03:06 PM
John in RI's Avatar
That's a PITA !!!
Good luck with that fix; gonna' take some patience,... at least the door panels are already off !!
Old Mar 12, 2020 | 03:24 PM
MicksIroc's Avatar
McCall
Jan 30, 2020 06:41 PM
rffy
Apr 4, 2012 09:32 PM
camaro8811
Apr 16, 2008 05:31 AM
1983sc
Jul 22, 2007 05:12 PM
Blackhawk355
Feb 4, 2006 12:47 AM
