Speedometer Needle
Car: 1988 Camaro IROC-Z
Engine: 5.7 TPI
Speedometer Needle
Long time listener, first time caller. I hope y'all get the reference.
While attempting the "use a fork to remove needle" method, I broke it. 145mph speedo.
What's the best way about getting a replacement these days? I worry that my clumsy hands and big self might destroy another. I'm going to assume it's buying another gauge or cluster.
This all started because it was reading between 3-10 MPH high, my dad bought the car new. I knew they had some tranny trouble back when it was still under warranty, other than that - it's pretty much still completely stock and untouched.
Any shops the forum trusts and/or recommends for restoration of gauges? I'm going with a restoration, not modification.
Any help and or information would be appreciated. I've been searching the forum like a madman, well the entire internet actually - and coming up with not much at all that relates to my exact problem. Thanks
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Speedometer Needle
I have no personal experience with this company, but I've seen their name popping up on various auto repair forums and yt vids: http://www.unitedradio.com/automotiv...manufacturing/
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
To get the speedo needle of you've got to turn it, then lift it; Never pull it or pry it.
https://www.thirdgen.org/forums/inte...le-broken.html
