speedometer needle removal
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
Hi, I have my cluster out and want to remove the speedo gauge and needle in my 85 z28.
I have plastic off and just removed the 2 little black screws that hold the speedometer...only the needle is left,,, how do I remove it without breaking it?
Thank you in advance,
Car: 1988 Camaro
Re: speedometer needle removal
It just prys off. You need to use even pressure on both sides of needle base. I always use a dinner fork to pop of gauge needles. If the tines are too close together on your fork just cut one off of it.
I use to get the oddest looks and questions from buddies when they saw a dinner fork in my tool chest lol.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
May I ask what your goal is?JamesC
Transmission: T5 WC
I have bought 2 used 145 mph complete clusters on ebay. They are worse than my cluster. Most gauges were not working. Junk. So I figured this way was the easiest way to have the 145 mph speedo. Looks better than 85mph!
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
To remove the needle without breaking it,...... Here's a thread with pics:
https://www.thirdgen.org/forums/inte...le-broken.html
You Can NOT simply change the face/bezel from an 85mph to a 145mph Speedo and "build" a 145 speedometer. The Speedo head itself is calibrated to the speed rated on the original face/bezel. By swapping just the face/bezel,.... you now have a 85 speedo head that displays the wrong speed on a 145 speedo face.
Do yourself a favor and simply install the entire/complete 145 speedo head into your original cluster.
All I wanted was to swap the black steel part and re install my actual speedo cluster
If you consider fixing the odometer, which will likely be broken, check out the following link:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Transmission: T5 WC
It won't be off a bit. It will be off a considerable amount. Your 85mph speedo will have the needle at ~3 o'clock for 70mph and that same location is ~120mph on the 145 speedo.
Transmission: T5 WC
85@IRocZ
Jan 14, 2016 02:01 PM
dbrochard
Jan 10, 2016 02:11 PM
formula00ra
Interior Parts Wanted
Jan 9, 2016 05:23 PM
