exploded diagram of cigarette lighter socket?
Old Aug 3, 2021 | 10:16 AM
ktthecarguy's Avatar
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi there,
I am installing my old cigarette lighter socket from my old console to my new one, and i reassembled it wrong. The socket was working before I removed it. I had to take it all the way apart because it was it was corroded and would not come apart, So I used a dremel tool and cleaned off the corrosion and I thought I reassembled it in the correct order, but I obviously did not. Now every time I put in a new fuse or plug in the socket, it blows the ACC fuse.
Does anyone have an exploded view of the socket parts, or can describe what order the parts go together?
Old Aug 3, 2021 | 08:56 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: exploded diagram of cigarette lighter socket?
I don't have a diagram, however, if you are blowing a fuse, it's likely that the positive and negative are shorting together, so the fuse is doing its job.
Old Aug 3, 2021 | 11:29 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Now is the perfect time to install a USB port in place of the old lighter socket...
Old Aug 4, 2021 | 01:48 PM
Drew's Avatar
There are only two parts. Most of the lighter sockets are fairly generic, get a new socket.
Old Aug 5, 2021 | 06:02 AM
On Probation
well, I solved it. I had the 2 washers reversed. I put the insulator washer in place of the metal washer, and it works. It no longer blows fuses, and the USB charger gets power.
And all for free!
slow_90firebird
Sep 26, 2014 07:50 PM
joekonik
Apr 30, 2012 10:40 AM
Stevolwevol
Aug 8, 2009 09:52 PM
VEGASIROC
Jul 6, 2009 10:44 AM
GTA88
Nov 16, 2000 03:34 PM
