Help me identify please?
Old Oct 22, 2021 | 01:37 PM
Johnny Gun's Avatar
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
I found this horrible solder job under the dash while removing my broken door chime and installing a radio retained power module this week.
Does anyone know what this particular wire might be leading to? I need to re-pin it.
Old Oct 22, 2021 | 02:15 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Help me identify please?
What year and engine and tranny do u have?
Old Oct 22, 2021 | 03:33 PM
OrangeBird's Avatar
Car: 1989 Firebird
Old Oct 22, 2021 | 03:55 PM
vorteciroc's Avatar
Top Answer: 1
That is the C210 Steering-Column Connector for Exterior Lights/ Stop Lights/ Hazard Lights, Etc.
The Wire that has some conductor showing is in the "P" Terminal Position.
It should be a White Wire...
and it goes to the C208 Connector next.
Old Oct 22, 2021 | 05:28 PM
Johnny Gun's Avatar
Car: '88 GTA
It's under my user name.
Old Oct 22, 2021 | 05:50 PM
Johnny Gun's Avatar
Car: '88 GTA
All my lights work but the front side markers. Would they be tied into this connector as well?
Old Oct 22, 2021 | 07:39 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Is that connector for the signal light switch?
Old Nov 21, 2021 | 11:18 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Old Nov 21, 2021 | 06:59 PM
Johnny Gun's Avatar
Car: '88 GTA
Thanks! That's a lot easier to read than my service manual.
Old Nov 21, 2021 | 07:05 PM
vorteciroc's Avatar
Top Answer: 1
Are you still working on this?
The Wire that you asked about is part of the Stop-Lamp/ Brake-Lamp (NOT Tail-Lamp) Circuit for Trans-Am Cars...
C210 Terminal: "P" (White Wire at the C210 Connector; changing to a Light-Blue Wire at the C208 Connector).
This circuit differs for "Base Model"/ Firebird Cars (NOT Trans-Am/ GTA Cars).
Front Side Marker Lights (One in each Front-Fender) are not part of the Circuit that we are discussing above.
The Two Circuits for the Front Side Marker Lights, do go through that same Electrical Connector (C210)...
but they use different Terminals:
-Left Side Marker illuminated by C210 Terminal: "H" (Light-Blue Wire).
-Right Side Marker illuminated by C210 Terminal: "J" (Dark-Blue Wire).
Old Nov 21, 2021 | 07:15 PM
Johnny Gun's Avatar
Car: '88 GTA
Not as of right now. I'm currently diagnosing my fuel gauge. It was reading over full, but I grounded the wire and it slowly swept down to empty. I think the problem is between the tank plug and the point where it goes into body behind the seats.
Old Nov 21, 2021 | 09:16 PM
vorteciroc's Avatar
Top Answer: 1
The Wire from the First Image that you Posted, is C210 Terminal: "P".
It is part of a very simple and short Circuit.
Here is the entire Circuit... layed-out as follows:
-Connector C210, Terminal: "P" (White Wire) on Steering-Column to Connector C208, Terminal: "A" (White Wire).
-Connector C208, Terminal: "A" (White Wire) behind Driver-Side Kick-Panel, splits into C208, Terminal: "B" (Light-Blue Wire).
-Connector C208, Terminal: "B" (Light-Blue Wire) to Brake-Pedal Switch, Terminal: "A" (Light-Blue Wire).
-Brake-Pedal Switch, Terminal: "B" (Orange Wire) to the Stop/ Hazard Fuse (Orange Wire).
Old Nov 23, 2021 | 08:13 AM
BURD's Avatar
You can get the correct terminal crimp on end from a terminal supply, ive done it, they will slide out with a very small screwdriver.
Old Nov 23, 2021 | 04:58 PM
Johnny Gun's Avatar
Car: '88 GTA
Thanks guys for the info. I'm putting her on the road this weekend and continuing on with the never-ending electrical work.
battmann
Car Audio
Nov 17, 2020 01:59 PM
KITT1983
Dec 24, 2011 01:43 PM
Zyddian
Dec 23, 2003 06:09 PM
Deimos
Car Audio
Aug 3, 2002 03:39 AM
