1992 V6 stalls due to no spark
Old Jun 10, 2022 | 05:47 PM
magnus01's Avatar
Hi guys I have a 1992 Firebird 3.1 v6 automatic which has a bit of a problem. When I'm driving it sometimes stalls because it doesnt get any spark.
First the speedometer will stop working and drop to 0, then after about 30 seconds or longer the speedometer will work again and at the exact same time my engine shuts off. Turning over the key to start it again doesn't work, it will turn over but it won't get going again. But if I instead turn the ignition off and then start it again it will fire right up and I can keep on moving without having to stop.
I replaced the ignition module but that didn't help. Does anyone have any idea what it could be? It's my only car at the moment and having to deal with this every single day has been torture for me.
Old Jun 10, 2022 | 05:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1992 V6 stalls due to no spark
Any codes like 24 ?
Old Jun 10, 2022 | 05:52 PM
magnus01's Avatar
Any codes like 24 ?
I don't have anything to read it sadly, what kind of obd scanner would I need? I've mostly had older carburated cars before this. And what does code 24 say about it? Thanks for your reply.
Old Jun 10, 2022 | 05:53 PM
Engine: Lb9
Transmission: M20
So the check engine light is on ? Got a paperclip ?
Old Jun 10, 2022 | 06:07 PM
magnus01's Avatar
There's no check engine light on from what I remember, I think I would have noticed that but I'll check tomorrow, it's 1 am here right now. But please tell me what to do with the paperclip
Old Jun 10, 2022 | 06:22 PM
Engine: Lb9
Transmission: M20
https://bestobd2scanners.com/how-to-read-obd1-codes/
lots of articles just jumper the aldl a to b to blink codes
Old Jun 11, 2022 | 05:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Try another ECM, it is a '7730. Should have an AZTY MEMCAL in it, if not can swap over the one from your current ECM.
RBob.
Old Jun 11, 2022 | 09:23 AM
Engine: Lb9
Transmission: M20
Rbob, could the ecm shut off if injectors are shorting or would that just shut down there driver not ecm ?
if you need a ecm , I think that’s the culprit the speedometer signal runs though it is why your seeing it glitch.
https://www.thirdgen.org/forums/engi...2-tpi-3-a.html
Old Jun 12, 2022 | 02:25 PM
magnus01's Avatar
Ive had some trouble logging in but Im back. I tried the paperclip trick but no check engine light appeared anywhere. Changing the ecm is a good idea, does a manual 3.1 v6 firebird have the same one as my automatic 3.1 v6? If thats so I know where to get another one. Thanks for the help guys.
Old Jun 12, 2022 | 02:35 PM
Engine: Lb9
Transmission: M20
The 1227730 is the same 3.1 automatic or manual just swap memcal chip.
Old Jun 26, 2022 | 05:50 AM
magnus01's Avatar
It took me some time to get my hands on a 7730 ecm (I live in holland) but I swapped it and my Firebird runs perfectly now. Thanks guys.
Old Jun 27, 2022 | 01:29 AM
Blakteky's Avatar
Car: 89 chevy s10
Engine: L31
Transmission: NV3500
Axle/Gears: 9 bolt BW 2.77 Posi
I wonder what was wrong with your old PCM? That's great the new one fixed the issue.
jloomis95
Apr 15, 2018 07:37 PM
BiggTipp7
Dec 1, 2013 11:47 AM
IIxDCxII
Jan 18, 2011 10:08 PM
