Electrical Issue
Old Aug 8, 2022 | 09:46 AM
tylrdenny's Avatar
Car: 1989 Camaro RS Convertible
Engine: 5.0 L, 305
Electrical Issue
So I have a 1989 Camaro RS. I am having some electrical issues. When I bought the car the radio did not work, so I put a new one in and it powers on but no sound, all the fuses are good except the power door lock fuse which keeps blowing. But today I turned my wipers on and the radio started playing music but then stopped until I put my wipers back on, any ideas?
Old Aug 8, 2022 | 09:56 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Electrical Issue
Where was accessory power robbed from ?
Old Aug 8, 2022 | 09:59 AM
tylrdenny's Avatar
Engine: 5.0 L, 305
I'm not sure, how do I figure that out?
Old Aug 8, 2022 | 10:16 AM
Engine: Lb9
Transmission: M20
What schematic did you use or wire color for it ?
http://www.austinthirdgen.org/mkport...1992_radio.jpg
Old Aug 8, 2022 | 11:27 AM
tylrdenny's Avatar
Engine: 5.0 L, 305
I used this from Crutchfield
File Type: pdf
Old Aug 8, 2022 | 01:58 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
It sounds like you have your device powered from the circuit that runs the wipers rather than---as the Crutchfield instructions specify---one constant 12-volt source and also one 'switched' (by the ignition switch) power source.
You'll need to search either this site or The Google for a copy of the factory wiring diagram for your vehicle, determine which fuse block position(s) will be appropriate, and then rewire the radio accordingly.
Old Aug 8, 2022 | 02:18 PM
tylrdenny's Avatar
Engine: 5.0 L, 305
Ok I will do some more digging, I appreciate the help, stupid electrical gremlins 😐😐
Old Aug 8, 2022 | 02:57 PM
tylrdenny's Avatar
Engine: 5.0 L, 305
Ok, so after digging around under the dash I found that someone has jumped a wire to the starter. The guy I bought the car from said he had to get a new key made. So maybe someone bypassed the VATS system which is messing everything up due to the ignition controlling power to different circuits.
joelovescamaros
Nov 28, 2025 01:33 PM
Thomas Mcquirt
Mar 3, 2021 01:23 PM
89_iroc_z
Oct 31, 2010 12:24 PM
Atremise
Jul 25, 2010 05:47 PM
kretos
Oct 3, 2004 06:56 PM
