How do I crimp accessory fuse block terminal with bar?
Old Apr 30, 2023 | 05:06 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
I’m trying to add an accessory fuse block in my car and I can’t figure out how to crimp a terminal that is connected to the bar. I want to connect one power wire from the battery to an end terminal of the 4 connector bar and then the other side of the block will have single connectors for each separate circuit with a fuse. I can’t fit a crimper on an end terminal with the bar because the next terminal is in the way. How do I do this??
Old Apr 30, 2023 | 05:49 PM
Re: How do I crimp accessory fuse block terminal with bar?
That "bar" is for automatic crimping machinery. It makes the connectors to be a BELT, instead of a TANGLED PILE, that feeds into the machine.
To use such a thing with a hand crimper, cut the pins off of the bandolier so they look like the one on the left. That's what the auto machine would do in any case. The bandolier isn't supposed to be part of the finished product.
Old Apr 30, 2023 | 05:59 PM
battmann's Avatar
If I cut the bandolier apart then I’ll have to run 4 separate power wires (1 per circuit) instead of just one. Is there a way to accomplish this more like the factory fuse block does where one larger gauge wire feeds multiple circuits?
Old Apr 30, 2023 | 07:04 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.ebay.com/itm/26557560919...mis&media=COPY
or can get a fancy one
https://www.ebay.com/itm/31387584230...mis&media=COPY
Old Apr 30, 2023 | 08:01 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
I got the cheap one and wasn't too impressed with it, but maybe it was my (lack of) technique.
I have a similar situation where I want to use one wire to feed the 12v+ to 4 fuses (for 4 relays) that have those same connectors. I really don't want to run 4 individual wires...
Old May 1, 2023 | 12:28 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
What is the part number for this? Is this block meant to except the all four terminals together or split apart? The cheap crimpers for these terminals kinda suck, even the more expensive crimpers require some familiarity to get it right, we use these terminals here at work aocassionally, It may not be correct, not at work but as I don't have a set of these very expensive crimpers, I've installed these on home projects using needle nose pliers using some solder.
Old May 1, 2023 | 12:42 PM
Engine: Lb9
Transmission: M20
https://www.bmotorsports.com/shop/pr...roducts_id/507
delphi
12004943
Old May 1, 2023 | 01:26 PM
battmann's Avatar
There's a few companies selling this part. The part I posted a picture of is Dorman 85668. Racetronix has the same thing as FBK-001. Painless has it as 30002, etc... The bandolier will fit in one side of the block or you can cut it to make four separate terminals if you want.
My plan was to try and use empty fuse locations in my factory Trans Am fuse box for some accessories. I wanted to run a 12ga wire from the battery to one of these bars with three terminals. Then I could wire the other side of the circuit with 16ga wire for two 5A and one 10A accessories that I want to be able to turn on when the car is off.
Old May 1, 2023 | 05:48 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Insert the wire fold the ends over and solder it.
Old May 2, 2023 | 01:46 AM
vorteciroc's Avatar
Top Answer: 1
Wow!
Pack-Con Buss-Bars... Take me back to 1976!
The 4-Terminal Pack-Con Buss-Bar ONLY needs one heavy-Gauge Wire Crimped into One of any of the Four Locations.
Crimping is completed in the same method as the Metri-Pack 280 Series Buss-Bar shown below:
The Conductor is Crimped towards the Terminal End.
The Insulation is Crimped Towards the Wire End.
Old May 2, 2023 | 02:04 AM
vorteciroc's Avatar
Top Answer: 1
Also not a bad time to update to the modern era...
Sealed 6 ATM-Fuses (using Sealed Metri-Pack 280 Components) that is fully Modular with Relays and Circuit-Breakers that accept the ISO 280 Standard:
skinny z
Oct 5, 2017 11:50 AM
2mnytys
Sep 19, 2017 11:33 AM
sharlimar
Nov 11, 2015 08:16 PM
fermium257
May 26, 2010 12:36 PM
PyRo9862
Jan 2, 2004 10:46 PM
