Converting AC to non-ac car wiring blower switch
Old May 19, 2024 | 07:36 PM
dcd2236's Avatar
Car: 1987 trans am, 1988 Formula
Engine: 305 LG4, 305 LB9 TPI
Transmission: 700R4 in both
Ok here is what I got
Got an 88 firebird formula. I have converted the climate control panel and under hood and dash to non-ac controls with cable controls. Most have said that you can use the factory AC wiring for the panel but im finding that's not so. I have changed the blower motor resistor over to the 4 speed resistor so the stock under hood plug will plug to it.
The AC climate control panel had a separate plug in addition to the plug going into the back of the blower **** switch.
The separate plug I believe is what has the main power for everything because when I probe it the first wire on the left it has 12v key on. The blower switch plug has no power on any wire. Does that 12 v wire need to be moved over somewhere to the blower switch so it can send power to the blower when turned on?
Old AC Control plug
Blower switch plug
kawaslut
Jul 24, 2020 09:11 PM
Tibo
Sep 3, 2004 04:28 PM
kptkid
May 23, 2003 12:22 AM
david auster
Nov 11, 2002 07:06 AM
Jason86Z28
Apr 8, 2002 03:18 PM
